10-05-2021, 06:09 PM | #1 |
Brake push rod assembly lube?
My instinct says these should be lubed. I used brake grease for the pedal sleeve/shaft, but that might attract too much dirt under the hood. I think graphite may have a place here, though I'm not sure they were even lubricated.
These are for power brakes (71ish), not sure what manual looks like....Thanks.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-07-2021, 12:34 AM | #2 |
Re: Brake push rod assembly lube?
For what worth, per the assem. manual the area is not lubed.
10-07-2021, 08:36 AM | #3 |
I've redone a few vehicles and have never lubed these parts...no issues. If you want to lube it, graphite would be the way to go every few months depending on how often it's driven/washed etc.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
10-07-2021, 02:10 PM | #4 |
Thank you
