10-08-2021, 04:25 PM | #1 |
Help Identify Inner Sport Bumper Brackets
I purchased these brackets off this forum. They were labeled as "Blazer rear inner brackets". I don't need these brackets, but before I try to sell them, I want to make sure they are advertised correctly. As I research, I have found photos that make me think these will fit sport bumper trucks also. Did 69-71 Blazers use the same inner brackets as fleetside trucks? Any info would be appreciated.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
10-08-2021, 08:17 PM | #2 |
Re: Help Identify Inner Sport Bumper Brackets
I think they are for coil spring trucks I have the same brackets and they don't fit a 1970 Jimmy only 1 bolt hole lines up
10-08-2021, 10:28 PM | #3 |
Outer brackets are all the same, but inners are different from leaf to coil springs
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
10-09-2021, 05:04 AM | #4 |
Someone please correct if wrong. What you are stating would only be true for SWB leaf vehicles. From what I understand the leaf sprung LWB trucks use the same brackets as the coil trucks. The rear shackle hanger is farther from the rear of frame and does not require a different bracket.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
10-09-2021, 09:48 AM | #5 |
You may be correct, I just know leaf and coil use different inner brackets.
