Intank fuel pump set up for EFI
Anyone figure out a way to run an in-tank fuel pump for the sniper EFI? I don't see that they make a kit for the fuel tanks that are inside the cab. I was hoping with all the different customization people do in here someone might have figured this out. If so could you help me out on how you did it? I would much rather go in-tank than in-line. Thank you.
1972/Sierra Grande k2500 / 383 / th350 with Gear Vendors / 4.11 / 4" lift with 35s / Eaton Rear Axle |
Re: Intank fuel pump set up for EFI
Yes, several of us have installed in-tank fuel pumps in the original in-cab tanks.
Visit the LS Swaps forum and do a search. My installation works great, but is a bit noisy. What I did not do, but will be doing in the near future, is wrapping the tank in sound deadening material. I have a new tank on order due to unrelated tank issues. I believe the pump I used was a GPA-2 pump from Tanks Inc. You will also need the gasket kit 3G-KIT and split ring 3TR again from Tanks Inc. Cost including shipping will be about $255.00 Please note that I did an LS swap so the engine computer is controlling the fuel pump and will shut it off if the engine dies. Please ensure your installation has similar safety controls. Assembled pump photo. I cut hole and welded split ring to tank (careful with this...I filled tank with water before welding). Hole is adjacent to level sender hole. [IMG] ![]() Last edited by Davidf; 10-14-2021 at 02:08 PM. Reason: added pump photo |
I started looking into this a few months ago. I have not found a "kit" but looked at similar things as Davidf mentioned. I have settled on one of two ways to use the stock tank.
1. Utilize the Fitech or Edelbrock sump and factory engine mounted pump. 2. Use the Holley in tank pumps for 73-87s. The mounting flanges appear to be the same, but the shape / length of the tube will need to be changed. These are nice because they are internally regulated though I already have the 72 return line. As mentioned, the in-cab noise is a consideration |
#4 | |
They are compatible yes. It's a pretty compact sump system and looks easy to plumb and connect.
I used one from a 1994 Toyota Camry that I had in original tank and the noise is not bad, I can listen to the radio just fine, my fuel tank is not lined
#7 | |
![]() Join Date: Jul 2000
David, what do you suggest for shutting off a fuel pump when the engine is not running, car is on its side or top, etc?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#9 | |
