01-24-2022, 01:59 AM | #1 |
Retro Fit In Tank Fuel Pump (carb)
As anyone retrofitted an in tank pump in to a Blazer fuel Tank?
I am thinking of doing this, will be still running a carburetor, with possibility of EFI later. No plans to make anymore than 400hp, using SBC. We believe there is a current issue with fuel feed when tank gets down to around 1/4 tank on gauge, so in all likelihood will be dropping tank and replacing hoses. I see Holley have one, https://www.holley.com/products/fuel...s/parts/12-129, which can be upgraded to EFI by changing internal regulator Tanks Inc also have one, https://www.tanksinc.com/index.cfm/p...prod/prd84.htm, which uses an external regulator, https://www.tanksinc.com/index.cfm/p...cat/cat163.htm A query I have is that my understanding is a Blazer tank is 13" deep, but Holley list maximum depth 12" and Tanks Inc 10.5" Any other suggestions? |
01-24-2022, 06:35 AM | #2 |
Re: Retro Fit In Tank Fuel Pump (carb)
I extended my tanks Inc. bracket to fit into my Blazer tank. So I don’t think the maximum depth is something to really worry about.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
01-24-2022, 09:48 AM | #3 |
I used this one
20190930_180411 by 20191002_093933 by [url=https://www.flickr.com/photos/97391199@N06/]
01-24-2022, 09:51 AM | #4 |
01-24-2022, 10:54 AM | #5 |
What Jaros did;
OEM pump assemblies are a gift to us that do EFI conversions. Most are adjustable for tank depth, have a fuel level sender, keeps the pump always submerged in fuel no matter the level of the tank to reduce noise and heat. Best part is that they can be adapted to just about anything and are fairly cheap to buy. Boggles my mind that some still use inline pumps. |
01-24-2022, 09:13 PM | #6 | |
Yes the OEM is a great solution, but I would still need to install an external regulator for carb. I suppose no big deal to remove if switch to EFI down the track One of the things I like about the Holley as it has an inbuilt reg already set for 6psi, so is returnless fuel line. I can also make a shelf at 12" like has been done for the OEM pumps, this may help with clearance underbed Brothers also sell what looks to be the Tanks Inc and install video appears to be a Blazer tank, but web site also states max depth 10.5" https://www.brotherstrucks.com/1947-...tinfo/FIPK372/ |
01-24-2022, 10:23 PM | #7 |
Which ever one you choice, the shelf is mandatory, as there is very limited space between the tank and bed
The return line would also benefit the carb, to eliminate vapor lock Hope it works out for you, keep us posted, as solutions to problems are always helpful to the next guy The mounting ring for the pump is the key to success, looks like Hemi used a different one then mine
01-25-2022, 10:04 AM | #8 | |
This might be the right time to bite the bullet and go EFI. Once you do, you will never want a carb again. |
01-25-2022, 12:39 PM | #9 | |
01-25-2022, 01:16 PM | #10 | |
Americans have no idea the bull**** we have to deal with. Registering anything modified usually means you need to know someone that's willing to turn a blind eye to certain things, but the real problem here is getting it insured. I wanted regular daily insurance for my Blazer, but I had to answer a few questions first. The first thing they asked was "does the vehicle have the original fuel pump"? I kid you not! Because I'm using a 5.3, they could not insure it, so I reluctantly had to use Hagerty. It was then that I found out that Hagerty puts way more restrictions on Canadians than Americans. |
