03-22-2022, 05:53 PM | #1 |
four fuses and two relays. need help.
Hey all, i haven't posted in a long time. my 4 fuse block has full power without key on. i dont think this is right. when i turn (to the on position) the key nothing happens. i used lt1 swap for the fuses and relays. even the fuel pump runs for 2-3 seconds when i connect the battery ground.
2002 5.3 DBW |
03-22-2022, 06:57 PM | #2 |
Re: four fuses and two relays. need help.
this is a 1953 ad, s10 swap. s10 wiring from cab.
03-23-2022, 06:36 AM | #3 |
It sounds like you have battery power to the ignition wire that goes to the ignition relay.
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. |
03-26-2022, 08:11 PM | #4 |
ok it's still not right. i removed the constant wire going to the cab. put a constant wire to feed harness only. still have the same problem. dose this mean i have wire something wrong in the harness?
03-27-2022, 11:04 AM | #5 |
Yes, you have something wired wrong. There should be a constant hot and an ignition (key on) hot to the ignition relay. It sounds like that isn't hooked up right. What wire are you using to power up the relay?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-28-2022, 12:00 AM | #6 |
Ditto to the two previous posts. Check to see if you hear the relays click when you connect battery ground. Constant +12v should go to common terminal on relays. Switched +12v power should be going to the coil on relay. The wire on the coil of relay should not have power when ignition is off.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
03-28-2022, 04:28 PM | #7 |
i have a constant hot from the battery to power relay and PCM. keyed pink wire hot in start and run for relay. without turning the key all fuses have power. yes i hear the relays and fuel pump for around 2-3 seconds. I followed ucandoit site to wire relays and changed it to lt1 swap with the same result.
03-28-2022, 04:45 PM | #8 |
pink wire is only hot with key on.
03-29-2022, 06:26 PM | #9 |
ok, with constant hot wire i am getting power to the fuses thru what is suppose to be injector wires.
03-29-2022, 10:18 PM | #10 |
If you have constant power on the injector wires, then you're probably back-feeding power to the whole harness. You don't have something wired right. Have you pulled the relay to see if the constant power goes away?
04-19-2022, 04:16 PM | #11 |
low n' slo
quick question. you only used lt1swap for their diagram, or were they the ones that actually rewired it for you?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
04-20-2022, 11:13 PM | #12 |
Blue 67
I am glad you found the problem.
Based on what you have explained, I thought you wiring to the main relay (relay's posts) may have been mixed up. You may want to check on that if you have not already. Good luck.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
04-21-2022, 08:49 AM | #13 |
I used lt1swap diagram . He did my computer.
04-22-2022, 08:43 AM | #14 |
low n' slo
ah OK. ya I plan to send them the computer as well, just wondering if I should rewire myself or send them mine to rewire.
