04-13-2022, 07:34 PM | #1 |
1970 jimmy front leaf spring bushings
Order bushings for 1970 jimmy from brothers got 8 1 1/2 ones and 4 1 1/8.
Put 4 of the 1 1/2 in the front and the 4 1 1/8 in the frame. Have 4 1 1/2 that don't fit I the other spring bushing to big and the 1 1/8 is to small. They are all 3 different diameters. LMC truck shows that they are the same size as the ones in the frame.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
04-24-2022, 02:13 PM | #2 |
Re: 1970 jimmy front leaf spring bushings
Hello, just crawled under my K1500 and it looks like they are all 1-1/2" bushings, but I have the HD front springs option so that may be the difference.
Edit I am incorrect the lower rear leaf eyelet looks to be a 1-1/8". Last edited by Bobillot; 04-24-2022 at 03:05 PM. |
04-24-2022, 02:49 PM | #3 |
You might want to check with Rockauto.com I just redid all of mine at the rear of my 70 C20. Also ordered new shackles as the bushing is not replaceable in this location. I cross checked rock auto with every other place I could find online to make sure I got the correct ones. A real pain to replace, watch a couple of utube videos for suggestions.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
04-24-2022, 03:07 PM | #4 |
Did you press out the metal outer sleeves of the original bushings? If you are installing a polyurethane kit it says in the installation instructions to press them out.
04-24-2022, 07:49 PM | #5 |
Got it all out.
04-25-2022, 12:19 AM | #6 |
Well I'm sorry, I'm out of ideas.
