![]() Join Date: Jul 2008
67/68 gray wheels and front?
I think I've seen this discussed here before, but couldn't find what I needed in a search.
I've seen 67's and 68's with the steel wheels painted either white or gray and the area around the front grille painted white, gray or body color. What dictates this? I'm looking at a 67 that has gray wheels but body color around the front grille. I realize that over the course of 50+ years may things could have been changed on a truck, but am wondering if there was some sort of package or RPO that dictated the color of the wheels and grille surround area?
Dave R. 1972 K20 1972 C20 Highlander 1967 C10 |
![]() Join Date: Feb 2002
Re: 67/68 gray wheels and front?
Stock *2WDs for MYs '67/'68 had Argent Silver wheels -- which would look grey after 55 years or so. White was not stock on wheels... I re-engined my '68 C/10 in 1977 and -- while it was ''down'' -- spray-painted the OEM wheels in White, which I thought looked better with the Whiteface trim on my Stepside. [*Stock 4WDs got Black wheels.]
Someone at the Factory decided what accent colors went with certain body colors. In the Model Year '67, only Grille Molding rings and the Headlight Bezels got the contrasting color. The Grille was the same solid body color. With MY '68, the Grille itself got accent colored, and the above parts were a bright anodized aluminum. Plus more trim out of the same anodized aluminum covered the fender ''eyebrows'' and leading edge of the hood. [Some early '68s had no trim.] GM Parts only ever carried the 1968 anodized aluminum trim pieces as replacements. [Their cross-section is a kind of Z-shape.] The Factory 1967 hoop-like Grille Moldings were steel, painted in the accent color. The were a shallow D-shape in cross section. They were never available as replacements. Before repop vendor catalogs, it was ''hip'' to get the 1967 hoops chromed. So junkyards quickly became devoid of such pieces. Color contrast schemes, as I remember were: [BODY COLOR/trim color] ORANGE/white MED METALLIC BLUE/silver BLACK/white BLACK/orange BLACK/silver BLUE/white RED/white YELLOW/black LT GREEN/white That's not the total of all the combinations. It's only what I can remember at 72.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-22-2022 at 08:06 PM. |
#3 | |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
So then, from the factory:
67 front - always body color 68 front - body color, white or silver/gray? 67 wheels - silver/gray or body color (never white?) 68 wheels - silver/gray, white or body color? I'm curious what would dictate the color used from the factory.
My 68 had grey wheels and white surround on the grille but mines a golden so it had a different paint treatment anyway
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#6 | |
#7 | |
I suspect, since women were employed in the Trim Shop, some feminine agency was at work here. But in truth, I'll never know. ![]()
Life is a learning experience.
This what you are looking for? My truck was stock with the gray in the grill so it matches up with the wheels nicely. At least I think it does.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
![]() ![]() Join Date: Jan 2005
My truck is stock painted 67. The roof was once white I believe but the inside grill shelf area is definitely silver. Not sure if that was done by a PO but it sure looks factory.
The air deflectors inside the Grille on my '68 C/10 Stepside are original. Truck has original 516 Orange exterior, Orange/Fawn interior, and Whiteface grille. Tailgate letters are white.
The Deflectors look charcoal gray now, but I recall they were originally Black. I bought the truck in 1973 in California. It has since spent most of its time in the intense sunlight of Arizona. On the other hand, I have a '67 K/10 Suburban. I hit a deer in 1994 and had to replace the Grille with one from a '68 Sub. It's Argent Silver, the donor was light metallic blue. OK. So I guess the Silver Grilles got a silver-gray finish.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-23-2022 at 06:47 PM. |
#13 | |
![]() Join Date: Dec 1999
No, the ones in my second picture were from a Grille I salvaged from a '68 Suburban, after I hit a deer in my '67 Suburban and smashed the original. That truck was light metallic blue and had an Argent Silver Grille. The deflectors were not black on that one, but a silvery grey.
#15 |
Most of the the trucks I see that have either a white or gray/silver painted front seem to be 68's and also have and stainless molding around the perimeter of the grille area that marks the change from body color to white/silver. The stainless molding is part of Z61 Custom Appearance Package, I think? Maybe that package dictates the white or silver/gray front? And then the wheel color matches? The first three pics are of 68's that have that trim piece.
Most 67 pictures I've seen, show the front being body color. The last two pictures are of 67's and I know the red one has the the Z61 Custom Appearance Package but no stainless trim piece. Maybe the stainless trim piece around the perimeter of the grille is 68 only, and hence only 68's can potentially have a painted front?
#16 | |
But you are correct about the ''Icing'' trim being Model Year '68 only. I have seen '68s w/o it, but I'm not sure if that wasn't a very early [during 1967] build, or the PO nixed such fancy foolishness at the dealer's. Or a collision shop didn't bother with restoring the Icing trim. Also, I'm not sute if it was a custom job, but I have seen a Yellow '68 truck with a Black Grille.
#17 |
![]() Join Date: Jan 2007
1967’s had a body color grille with grille hoops only (chromed or painted).
1968’s had a white or argent grille with chromed grille hoops plus trim around the perimeter. I’m not positive on the wheels, but I do think 67’s had body color wheels at least sometimes, but 68 was white or argent (to match the grille).
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#18 | |
[1967 steel D-shape hoops were a popular junkyard item to be chromed by customizers, but the only source was a donor '67] C/ Series '68 trucks had Argent wheels, K/ trucks had Black wheels. White wheels would be aftermarket. Body color, I don't know about. Maybe an RPO or dealer upgrade.IDK. My C/10 Stepside has a Whiteface Grille, and it originally had Argent 5.25x17.5 6-lug rims. My truck was a fleet order unit. No frills.
#19 | |
I’m having 67 hoops and headlamp doors chromed for my 68 bought the last year at SETN
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 08-24-2022 at 08:51 PM. |
#20 | |
Are the '67 Headlight Bezels also steel? My '67 K/10 Sub had a Grille with the hoops and deflectors removed. They were still off the truck when I impacted Bambi's big brother. They were a dark blue. Truck and Grille were White. The HL Bezels were the '68 type anodized aluminum. I bought that truck in '93, so a lot can happen in 26 years. Urban Dictionary won't translate SETN. 10-9?
#21 | |
Yes the headlamp bezels are steel also
#22 |
In '67 wheels were either black or painted body color on fancier trucks. Hubcaps white. No trim surround for the grille area, so the grille area wasn't painted an accent color. The deflectors are not painted as trim.
'68 is when you saw the argent wheels and hubcaps, bumpers, etc. White was still used in some cases and that is what is unclear. Most believe that had to do with body paint color or 2-tone paint
