03-05-2023, 12:39 PM | #1 |
Anybody run the Rosta of DD cruise on their swap?
I bought the Rosta Cruise Control kit, but cannot seem to get it to work. I checked the part numbers and they seem to be different between the 2 kits, although many said they were the same.
I am getting the voltage in/out, but it won't engage. The LED in the back is not lit either. Whether that is for the DD version only, I am not sure. Last edited by Joyridin; 03-06-2023 at 08:30 AM. |
03-05-2023, 07:08 PM | #2 | |
BMW & ASE Master Certified
Re: Anybody run the Rosta of DD cruise on their swap?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
03-06-2023, 08:33 AM | #3 |
03-06-2023, 11:33 PM | #4 |
Defiantly interested in cruise control with the L83 swap. One of the last things I want to get working on mine too, but use the factory switch, and not theirs...
If you work it out, let us know how it works for you. clint
03-07-2023, 07:57 AM | #5 |
You can use the factory switch. The problem is the voltage. The unit requires 4v on both pins, but the pedal requires 4v on one pin and 2 on the other. The Dakota Digital unit uses the same 4/2v set-up. They tell me theirs will work. I might have to go down that path.
03-09-2023, 11:23 PM | #6 | |
maybe of both cruise setups, DD and Rasta... clint
04-07-2023, 03:02 PM | #7 |
WOOHOO! I finally got the cruise working! A bit harder than I originally anticipated, but it does work well.
04-09-2023, 04:28 PM | #8 |
what was your solution? parts list available?
04-10-2023, 08:14 AM | #9 |
The easiest thing to do is buy the Dakota Digital CRC-1000 cruise control. All the wires match up and you will have it working in a few hours. It is that easy to plug-n-play.
Unfortunately, I was told the Rostra kit cruise control and the DD are the same. Yes, the actual box with the electronics is the same, but everything else is different. I basically had to rewire the Rostra cruise to match the DD kit. The two kits use different plugs and a different set-up. The Rostra works fine if you have a newer vehicle running the complete canbus/brake system from OEM. The DD kit uses your brake switch (and clutch if you have a stick), and a few other variables to make the cruise work. I thought I could save almost $200 by going with Rostra, but all said and done, I was probably about $50 ahead with no warranty. |
