Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 03-07-2023, 12:40 AM   #1
c10sport
c10sport's Avatar
Trans Am with a bed
This was a fun build and a really fun truck. I built it using nearly all GM parts to make it look factory and added a bunch of options and features a 1989 GMC never had such as heated, power and auto-dimming mirrors, tilt-telescopic steering, factory keyless entry and alarm and express down windows. I even moved the battery to the passenger side so i could use a 1988-89 Trans Am air intake.
Jay
2001 Pontiac Aztek GT
c10sport is offline   Reply With Quote
Old 03-10-2023, 12:03 AM   #2
Just call me Sean
Just call me Sean's Avatar
Re: Trans Am with a bed
Cool truck. What computer do you use to run the engine?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 03-13-2023, 10:41 AM   #3
Pampas56
Nice truck!
Is this a TBI or something else? The engine looks very nice.
89s didn't come with a tach dash as far as I know. Did you or a PO add that or did it come that way? I have a 91 tach dash and am curious how much work it will be to swap out the moon gauge dash.
Steve
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive!
1998 Dakota EC 250K miles- I guess I'm just a truck guy now!
Pampas56 is offline   Reply With Quote
Old 03-22-2023, 02:22 PM   #4
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Pampas56 View Post
Nice truck!
Steve
TPI - Tuned Port Injection
Never came in trucks, mainly Corvette and Camaro.
Hart_Rod is offline   Reply With Quote
Old 03-22-2023, 05:54 PM   #5
c10sport
c10sport's Avatar
I'm using one from a 1991 S10 4 Cyl with the original 1987 TA chip. I integrated the wiring harness from both the TA and the Sierra.
Nice truck!
Steve
It's MPFI. I added the cluster. No tach until 1991, however you got the easy swap cluster as if I recall, the hardest part will be running a wire for the tach, otherwise it's a plug in. Later clusters like mine required a lot of wiring mods and a DRAC module.
Jay
Old 03-22-2023, 07:05 PM   #6
Just call me Sean
How did you get around the VATS? Is that part of the reason why you swapped the steering column?
Old 03-22-2023, 07:12 PM   #7
c10sport
c10sport's Avatar
Someone had already been in that because I never did a thing with it, using the original lock cylinder. I built the column because I'm a masochist and like to build weird things.
Jay
Old 03-30-2023, 04:52 PM   #8
OutlawDrifter
All 1/2t pickups should have had the L98 in them from the factory as far as I'm concerned.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
