05-11-2023, 02:45 PM | #1 |
Rear shock relocation question
1964 Shorty Stepside, I just purchased the CPP relocation brackets, but they didn't co.e with any instructions. I have 4" drop springs, and wondering if I can just purchase 4" drop shocks, or if the brackets require a shorter/ longer shock? Just seeing if anyone else has installed these before. Thanks in advance.
05-11-2023, 04:25 PM | #2 |
Re: Rear shock relocation question
Personally, I would recommend that you install the relocation brackets and then cycle the suspension from full droop (i.e., lift the truck from the frame and let the axle hang) to full stuff (e.g., with the springs as fully compressed as you can get them) measuring at both extreme the distance between the upper and lower shock mounts. This will tell you the length of shock you need exactly versus just a guesstimate.
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
05-11-2023, 04:45 PM | #3 |
It's Better With Nitro
Not sure if this pic helps...this is at full compression. As Scott mentioned, I measured based on my desired ride height, and then measured suspension at full compression/extension to order my shocks based on the manufacturer rebound/extended and ride length specs.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
