![]() Join Date: Nov 2012
There's something fishy with this rear axle
I've got a rig that Im working on and do not know any history on it and during the test drive the right rear brake will lock up prematurely and there is something grabby going on,its a pulsing rhythmic grab. Also noted a severe shake in the back area of the rig like a wheel is bent or terribly out of balance. Up on jacks and upon inspection it appears someone has converted the rear axle to five from 6 lug and the center hole on the five lug brake drum is too small for the end of the axle flange to go through. They had washers on the right side to compensate for this and nothing on the left. I'm wondering if someone drilled the axles and used what brake drums they had available. Not sure where to go from here so wanted to hear what others might suggest before I dive in,thanks
#2 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: There's something fishy with this rear axle
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
![]() Join Date: Mar 2003
Either find a drum that fits correctly, machine the hole in the drum or pull the axle shaft and have the pilot cut down to fit the correct drum. Replace axle shaft with a real 5 lug conversion shaft
![]() Join Date: Feb 2016
Howdy neighbor! I'm pretty sure I have a factory 71-72 used axle and drum in the garage that should fit unless you have the narrower early axle. Let me know I'm in north Portland.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
455, that is too kind and much appreciated, if nothing more it would be nice to meet you.
#6 | |
