06-12-2023, 08:48 PM | #1 |
Boy is she rough…
…but they ain’t gettin any younger. My latest haul is a 65 C10 long fleet. Originally 525 Saddle and I believe a V8. I’d like to make this my last one, (lol) take my time and do it right from the ground up. I’ve started the easy part, taking it apart. We will see how it goes.
06-12-2023, 09:38 PM | #2 |
Re: Boy is she rough…
Well, it's all better from here. looking forward to progress.
06-15-2023, 09:09 AM | #3 |
I'm glad you're saving it....
06-16-2023, 11:10 AM | #4 |
Keep us posted!
1963 Chevrolet C-10 "Ginger" 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster |
07-31-2023, 09:27 PM | #5 |
I’ve blown it apart and started on the cab. Had to patch both pillars and both kick panels. There wasn’t much left. This is an OER full floor from summit. It took me about an hour to get this installed by myself (the old floor had already been cut out).
I’m very pleased with it. The only issues are the two top holes not lining up with my kick panel patch and the rear holes on the right side do not line up. I believe both of these problems are 100% my fault. This truck was so rusty the old floor pretty much fell out of it and I did not have a lot of reference points to work from when I welded in my pillar ends and kick panels. Now that I have a fixed point to work from (the floor itself) I am able to measure and see what needs moved. I think I’m going to heat up the seam at the passenger side b pillar patch and see if I can persuade it to where it needs to be. Then I’m going to right side up the cab, put the doors back on, and set it back on the frame and see how it all looks. After that I’ll do the cab corners and then spot weld it to the back of the cab. Then I’m going to replace the entire firewall. |
07-31-2023, 09:32 PM | #8 |
It’s been a few years since I’ve been really active here, so forgive me for forgetting your username Norm, but I appreciate your comment on my fb post about how these cabs were built from the floor up. That’s sort of how I planned to do this and it was reassuring to hear that.
07-31-2023, 10:37 PM | #9 |
Your progress is making me reconsider my path of rust repair. I was planning on just patching the inner rockers/floors, but that full floor pan sure does look like an easier option on paper. Please continue sharing your progress!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-01-2023, 03:03 AM | #10 |
Great work, I like that very much.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
08-01-2023, 09:43 AM | #11 |
I am always amazed at some of the work guys are doing to save these trucks. I don't think I could do this type of significant repair. Looks great, and it is great you are saving another.
08-02-2023, 11:55 AM | #12 |
nice work
1965 C-10 1/2 ton shortbed part time daily driver 1980 C-10 1/2 ton shortbed project |
08-02-2023, 12:41 PM | #13 |
Subscribed for that complete floor work and thank you for posting it up.
MusicMan70 1961 GMC Suburban |
08-05-2023, 07:18 PM | #14 |
08-06-2023, 05:53 PM | #15 |
I don’t know where I saw saddle, one of the paint charts may have had it wrong. Is that an exact match for the fawn interior? I had always heard that the interior fawn formula was not available.
08-06-2023, 06:02 PM | #16 |
I hung the doors I have. They aren’t great and I’m not sure if I will use them but they fit “ok”. They fit just “ok” before considering how bad the cab was. I unbolted the right rear cab support to floor and renamed those holes out to get the b pillar to go back just a bit and it helped considerably. The hinges need pins and I didn’t spend a whole bunch of time adjusting them and they both open and close now without issue. I marked the hinges and I’m pretty confident the floor is where it should be in relation to the pillars and can move on to the rockers.
08-10-2023, 01:05 PM | #17 |
Those holes not lining up are probably 99% not your fault. That's just par for the course, with Import patch/replacment panels.
On my '63, I'm working on the drivers side. Inner/outer rockers lower A piller, front cab mount, ect. I've probably patched/welded up 75% of the holes. Then rescribed and drilled them once the panels were aligned properly. Import patch/replacement panels. Often just look similarly correct. But, generally still need to be tweaked. Or just plain finished, where they are missing correct details. To fit comparably to the factory panel they're replacing. Looks great, with a full new floor in it ! Last edited by Grounded63; 08-10-2023 at 01:14 PM. |
12-29-2023, 02:49 PM | #22 |
When you get to the rockers, make sure the inner lip that the door seal fits over isn't sticking too far outward. We've seen a few trucks with aftermarket rockers with that lip too far out and it makes the door really hard to close because the seal gets pinched. You may have to cut it off and weld it farther inward to align with the door correctly.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-31-2023, 12:54 PM | #23 | |
01-16-2024, 11:03 AM | #24 |
Good job getting busy saving that one - it was about to become part of the landscape.
01-18-2024, 11:27 PM | #25 |
Great work so far! Good to see you on another project.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1998 chevy c1500 4.3L 5speed (My current driver) 2002 Chevy s10 4.3L auto 4x4 1971 mercury monterey wagon 400 auto To many projects! |
