New Member
![]() Join Date: May 2021
Gas tank move?
I'm a snowbird, so this winter while I'm in Florida I am having my bench seat redone (foam & OEM style vinyl). Having rockers replaced, gutter refinished, one door repaired, all the rubber in and around the doors replaced. Having the antenna hole, a spot light & rotary beacon hole filled. There are a few very minor dents, and that's it. I'll get it painted next winter. Only other improvement will be power disc brakes. Happy with the 292 & 4spd.
Sorry for getting long winded description.. So... If I have gas tank moved, will I pick up any space to slide the seat back farther? Otherwise I don't see it worthwhile. |
![]() Join Date: Aug 2014
Re: Gas tank move?
No, you will not gain any more room.
The seat back will touch the cab with the tank still behind it.
Az |
![]() Join Date: Oct 2020
Re: Gas tank move?
But by moving the tank out of the cab you will gain some extra storage area behind the seat. It also eliminates the gas smell, and increases safety.
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
Re: Gas tank move?
If you smell gas you have a leak. It's a lot cheaper to just fix the leak.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
![]() Join Date: Nov 2018
Re: Gas tank move?
New Member
Re: Gas tank move?
#7 | |
Re: Gas tank move?
New Member
Re: Gas tank move?
Thanks... But whatever I do have done, will be with new parts. I'm 72 and wrenching days are minimal! BTW: I've had it two years, drive it nearly every day in the summer at least 6 miles sometimes 20.. and the only thing I did was have a new exhaust system installed the day I got it, and a annual oil change.
![]() Join Date: Feb 2002
Re: Gas tank move?
Belly tanks are for sissies. I had a '67 Suburban, and I have a '71 Jimmy. A behind the seat tank never has any fuel flow issues. It's as safe in the Cab as your body is. Force great enough to rupture the tank would also be fatal for the driver, so it's a false sense of security for added fuel problems. The in-cab tank holds 22 gallons. Belly tanks hardly hold 20. I had to add a Holley electric fuel pump to the Suburban. The fuel sender in my Jimmy is unreachable, due to at least 48 bolts holding a steel shield under it. Not keen on slicing thru the back deck with a cutting wheel on a grinder so close to the belly tank to get to it. So I just log my miles and fuel intake, and use dead reckoning.
BTW, I like the orange truck in your avatar. I have a '68 Chevy C/10 Stepside in 516 Orange, with a 292 L6 and SM465 4-speed. I changed the original cab tank for another that was cleaned, in 1999, when the gasoline formula changed to no lead, and the ''new'' fuel solution was dissolving tank bottom sediments that were getting into my carb. l also had a chewed up filler neck from muscle-f@#!ing a lost-keyed locking gas cap.
