07-26-2023, 11:08 PM | #1 |
1974 Stepside Filler Neck?
Anybody have a source for a stepside fill neck?
Dorman and Liland don't make one for a stepside. Anybody using something else? |
07-28-2023, 02:01 PM | #2 |
Re: 1974 Stepside Filler Neck?
I bought a right side filler hose for my 1976 stepside from https://www.classicheartbeat.com/
I think these are direct links: Left side: https://www.classicheartbeat.com/pro...ller-hose-l-h/ Right side:https://www.classicheartbeat.com/product/belt/ |
07-28-2023, 05:21 PM | #3 |
I am looking for the steel fill neck the uses 3 phillips screws to hold it to the stepside fender that those rubber hoses fit onto.
07-29-2023, 11:39 AM | #4 |
Robert Olson Transport
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
07-29-2023, 01:10 PM | #5 |
As far as i know no one sells a steel filler neck for a 75 or 76 stepside.
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
07-29-2023, 10:02 PM | #6 | |
How much difference is there between a stepside fill neck and a fleetside fill neck if anybody knows? If it's just the pipe angle can i cut it off and weld new on? Edit: The stepside takes a 41127 gas cap and the fleetside takes a 41128 so something is different? |
07-31-2023, 11:55 PM | #7 | |
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
08-03-2023, 12:54 AM | #8 |
I have a couple for sale if you need one
08-03-2023, 11:50 AM | #9 |
I am interested pm sent
Lynn Last edited by LynnJr; 08-03-2023 at 03:27 PM. |
08-05-2023, 02:31 PM | #10 |
Still looking never heard from the above poster.
73-76 stepside fill neck |
09-14-2023, 11:43 AM | #11 |
Okay never heard from anyone so I ordered up a fleetside filler neck to modify it.
What are the differences. The fleetside and the stepside are very similar except the fleetside is longer on the main line and the return line both. If you don't need the barb you can simply cut to length and install it as is. If you want/need the barb then you would have to section it and weld it back together. The other difference is on the amount of protrusion from the fender. The fleetside protrudes half as much as the stepside does. This means the gas cap wants to make slight contact with the fender which you can live with or you can cut the attaching ring off and move it 1/4 inch and tack it back in place. |
09-15-2023, 07:51 PM | #12 |
Glad you got it worked out
