11-24-2023, 02:11 PM | #1 |
Junior Member
Power Brake Booster For 1966 K10
Hello Everyone
As I begin to prepare my truck to get the newly rebuilt 292 installed. I have been thinking about how I am going to add a power brake Booster for the front disc brake conversion without it hitting the air filter housing. I have aquired an offset air filter but do not like the look of it. I will use it if there is no other way. I was looking at a Chevy C30 with power drum brakes. It has a booster that is offset. I was thinking maybe going this way with a different dual master cylinder. The concept of doing this would be more original looking than the offset air filter. I am attaching a couple photos and would appreciate any info. |
11-24-2023, 09:37 PM | #2 |
Re: Power Brake Booster For 1966 K10
Have you looked into hydroboost instead of vacuum booster?
11-25-2023, 06:16 AM | #3 |
Junior Member
Thanks for the tip....no I have not I will though.
12-01-2023, 09:05 PM | #4 |
60-66 Nut
With the addition of one of my '63-'66 standard booster brackets you can bolt up a great number of different vacuum boosters as well as any GM hydroboost with the addition of one of my hydroboost mounting plates. Here is the for sale thread here on the forum.
http://www.67-72chevytrucks.com/vboa...d.php?t=339081 The hydroboost mounting plate. http://www.67-72chevytrucks.com/vboa...d.php?t=347480 I have been fabricating these since 2009 And our website where you can see all 35 of my products and make your purchase. https://customfab-cda.com
12-01-2023, 09:11 PM | #5 |
60-66 Nut
Also member Lugnutz65 upgraded his 6 cylinder truck to power brakes using one of my booster brackets.
https://lugnutz65chevystepside.weebl...chives/11-2019
