Throttle Postion Sensors.
I am planning to put a yet to be determined fuel injected motor in my Plan D truck project.
In order to run the transmission I want which needs a TPS among a couple of other inputs, but so does the engine management. So here's the issues. Can I splice the tps wire togather? From the trans, and ecm. Or is there a LS style throttle body with dual TPS sensors I can adapt too. |
Moderator
![]() Join Date: Jun 2017
Re: Throttle Postion Sensors.
TCI TPS Adapter Harnesses 377200
Summit has them...around $60 ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
![]() Join Date: Dec 1999
I do not think there will be any issues as you are just accessing the signal. I added another connector in parallel to ecm on the map sensor on my harness for the pwm fuel pump controller from Vaporworx that I am using. Carl at Vaporworx told me it is no problem.
Picked up an extension harness for the map. Less than half that adapter harness. It gave me a male and female plug, cut in half. I soldered one end on the engine harness and the other end will go to the controller. Here an extension harness for the tps https://www.ebay.com/itm/12086598680...375317008177ab A lot less just a little work. Just quick search, sure there are others. If buying the Summit wye connector you still need to purchase another pigtail to connect to it. Added cost.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 02-05-2024 at 03:02 AM. |
Thanks guys.
Just trying to learn right now, and get ready |
