04-29-2024, 12:55 PM | #1 |
Junior Member
Core support rebuild
My core support is rotted away from under the battery, can you guys tell me if they're symmetrical in the bottom corners before I start trying to fabricate a new piece please? Thanks as always
04-29-2024, 01:37 PM | #2 |
Re: Core support rebuild
There are patch panels available. See the thread below.
https://67-72chevytrucks.com/vboard/...rt+patch+panel
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
04-29-2024, 05:02 PM | #3 | |
Junior Member
04-30-2024, 10:21 AM | #4 |
They are symmetrical.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
04-30-2024, 02:16 PM | #5 |
Junior Member
04-30-2024, 02:48 PM | #6 |
I replaced the support on my 68 fitment was spot on . Wasn’t near as bad as yours if you want to retain the original you could use a repro as patch panels .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
04-30-2024, 02:58 PM | #7 |
Junior Member
I would happily use a repro but the shipping cost to the UK is absolutely crazy due to the size of it, more than trebbling the cost!!
04-30-2024, 09:33 PM | #8 |
I've made them myself in the past. Not too hard, especially if you're not too picky like me! Good luck, Rg
05-01-2024, 08:08 AM | #9 |
Didn’t look at the location . There are no distribution facilities in the UK ? Seems strange that a Chinese part would have to be shipped from the US to the UK
04-30-2024, 09:08 PM | #10 |
I just recently finished this task on my 66 core support to the two cornerswhere it rests on the frame. Not the easiest task without a bender/brake but it came out really well. In hindsight I might have benefitted time wise getting a new one but it's not a race and the satisfaction of a good repair offsets the frustration
05-01-2024, 01:02 PM | #11 |
You may want to consider the patch panel. It completes the difficult bends at the bottom. The rest may be flatter and easier to deal with. However, with out knowing your skills and resources my recommendation may be just that, a recommendation that is based on my skills.
Best of luck. |
05-01-2024, 11:10 PM | #12 |
Maybe figure out the dimensions of the patches needed. Maybe someone on here could cut them to size from a support offered on the parts page. Or someone with a semi usable one they have laying around. If not able to get all of them, you might get enough to make it easier to fabricate. Just an idle thought floating through my meager mind.
Smitty '71 Short Fleetside Spring Valley, Ca. |
05-02-2024, 07:39 AM | #13 | |
Junior Member
