01-01-2006, 05:41 PM | #1 |
electric fan temp switch?
I want to hook up my fan to a electric temp switch If any of you guys used one from another car or know a part # for one I can buy at an autoparts house It would be great
Thanks case |
01-01-2006, 11:06 PM | #2 |
18 Till I Die
Re: electric fan temp switch?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
01-01-2006, 11:22 PM | #3 |
Flex-a-lite Part# 31147-Adj. Temp Sensor
Turns fan on/off at the desired temperature. Dial-adjustable 180-240F. Gives the freedom to set one temperature for occasional high-demand use, then reset for highway or day-to-day driving. This is the one I use, works great!! |
01-02-2006, 11:24 AM | #4 |
Case, you might try Old Air Products. They have (2) sensors that come on at different temperatures and screw directly into a coolant port. They are out of FT Worth right off of 35W, that may be an option if you happen to be around that area.
01-02-2006, 12:06 PM | #5 | |
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
01-02-2006, 05:51 PM | #6 |
Vintage Evil
i thought i read somewhere you could use a temp sensor from an 80 something firebird that screwed into the manifold. I am getting ready to do this in the next few days as well
01-02-2006, 09:35 PM | #7 |
Dang...I cant find my catalog or I would give you a part number but they are 3/8" NPT temp switchs that screw into either a intake manifold port or head port, just like where you would put a temperature sensor for a gauge. When the engine reaches a certain temp it complete the circuit, when the temperature lower to a certain temp it opens up and shuts the fans down. There are (2) versions; one comes on at like 185 and shuts down at like 170 the other one is a higher temp. Give Old Air a call they are easy to deal with and I believe the sensor is about 22.50.
01-02-2006, 09:52 PM | #8 |
would the temp switch go on the groung side of the relay or the switch side?
01-03-2006, 12:17 PM | #9 | |
Vintage Evil
01-03-2006, 12:37 PM | #10 |
The +12V switched side of the relay.
01-04-2006, 10:00 AM | #11 |
Painless makes a sending unit that screws in the intake or head. Summit & Jegs sells them. The part number for the 185*/170* is PRF-30111 . I use it and it works good. The ground wire from the relay runs through it.
02-04-2006, 11:19 PM | #12 |
Any one know of a way of having them automaticly turn on at 170-175 and off in the 150 range?
Thanks Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
