Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 12-21-2009, 03:15 PM   #1
Thealien
Thealien's Avatar
LS engine swap info
A lot of questions have been asked lately about LS engine swaps. I have done a bunch of research and wanted to share what I have found. I hope it helps some of you out. Spend some time clicking the links, I have put a lot of the time into finding this stuff.
LT1swap lots of good wiring harness info with pictures and DIY tips
LT1swap
Lots of good LS information, what are the engine differences etc
LSprimer
LSprimer part II
A thread with LS engine swap questions and answers
Questions and answers
Another sites questions and answers
ANOTHER Question and answer thread
I will add to this post and thread as I go through my information
Thealien is offline
Old 12-21-2009, 03:16 PM   #2
Thealien
Thealien's Avatar
Re: LS engine swap info
Here are a few Engine sources to look at. I only have experience with Spaulding Automotive. I will elaborate more when I finally start my build thread.
SPAULDING AUTO
Here is a you tube link from one of their ads
Spaulding auto ready to run package
A couple people have bought from these guys
Schram auto
Pacific fab also does pull out and ready to run packages they also have a pretty cool 4X4 Ls crossmember I'll talk about later
Pacific Fab
Another vender that seems to have happy customers?
TNScrambler
And last but not least car part.com
Car Part.com
These are all just a reference, buyer beware and I am not recomending anyone at the moment. Ask questions, try local and good luck there are deal out there
Thealien is offline
Old 12-21-2009, 03:16 PM   #3
Thealien
Thealien's Avatar
Motor mounts and adapter plates
A couple of drawings of adapter plates, you would need two of either plate. This one would move the engine forward some.
They are showing the wrong hole countersunk. The hole that should be countersunk is the one between the two 1.75 inch measurements. The point goes forward and to the top. You have to countersink the hole that ends up behind the motor mount. The two plates will be mirror images with the countersunk hole on opposite sides of the plate. This is more like most of the aftermarket adapter plates. Most of them are 5/16-3/8 while these are 1/4 inch. The slight thickness differences could change engine height. I haven't read much about anyone having any issues with any of the different thickness adapter plates.
Scroll down
S&P
multi position adapter plates
MULTI POSITION
Moroso scroll down
MOROSO
Year one
YEAR ONE
Car Shop
Car Shop
And advance adapters. They are the only one that doesn't use the bottom bolt hole to position the motor mount? Hmmm
Advance Adapters
Now the drawings say 1/4 inch and all the rest are 5/16-3/8 which in my humble opinion will slightly change where your engine sits, higher/lower?
There are some issues with crossmembers on the 4X4 trucks causing motor mount and crossmember problems. My truck is stock height so these won't work for me but 4" plus lifted vehicles can use these from Pacific Fabrication
Pacific Fabrication
Thealien is offline
Old 12-21-2009, 03:17 PM   #4
Thealien
Thealien's Avatar
Wiring, harnesses, and connectors
If you want to modify your own harness there is some good info at LT1swap in the first post. Here is a list of links to places that either modify your own harness or build complete new ones. After contacting a bunch of them and having some emails go unanswered I am having my harness done by a board member
68 short step
Check him out for your project
Jims performance is very knowleagable and was the most reasonable. You must call him.
Jims
SPEARTECH
Wait4me
SSPwiring
Current performance also has fuse/relay panels connectors and will either rework your harness or build new.
Current performance
LS1wiring harness
Nelson performance
In addition to currant performance here are a few places to get fuse/relay panels, connectors, pins and bulkhead connectors
Pictures of GM connectors
Bulkhead connector
Terminals wire connectors
If you know the connector part number and pin part number this is the place
MOUSER
Fuse blocks
Fuse block wiring kits
Painless circuit boss
Painless
Autotrend fuse relay
The brake switch you will need if you want cruise control
AC Delco D850A
Thealien is offline
Old 12-21-2009, 03:17 PM   #5
Thealien
Thealien's Avatar
Transmission info and adapters
If my transmission ever needs a rebuild I am going with these guys. Check out all the pictures and attention to detail!
Finish Line Transmission build thread
Not a lot of info to post here. The harnesses can be changed from either a 4l60 to a 4l80 and the other way around. It is easier to alter a 4l80 harness for the 4l60 but both are doable. The 4l80 has 2 VSS sensors and the 4l60 has one. If you have a 4l60 harness you have to add the other VSS for the 4l80. If you have a 4l80 harness you remove the extra VSS for the 4l60. It matters which one but if you are doing your own harness you will have the pin outs. If you are having it done they should know what to do if not find someone else. In the big round connector there are a couple of wires moved between the 4l60 and 4l80.
HERE IS THE DIFFERENCES IN THE TRANSMISSION WIRING
There is a big switch on the side of the transmission. It is your park/neutral safety switch. Many people remove this and that can be done. The PCM does use that information for more than the safety and gear indicator but from what I have read it is not necessary. Here is what I have found
The PCM uses the signal to adjust idle speed based on whether the car is in gear or in park/neutral.
As soon as the PCM "sees" the car go in gear it drops the idle speed by around 100 rpm to prevent jerking going into gear, and to prevent tugging at the torque converter.
It can be considered as optional on a swap. As long as the line is left open the PCM will always assume the car is in gear, and will drop to lower rpm when the engine is started. This also causes a much quicker rpm rampdown on a cold engine start.
Some aftermarket wiring harness companies that have no clue as to how the PCM works will wire this line to ground which makes the PCM think the car is always in park or neutral. On some applications this allows some diagnostic tests to be skipped (EGR, purge, etc.) so that these items can be left off without setting a code. The problem is that the idle is too fast then, and the car wantts to pull a little when sitting still, as well as other issues.
I have a 4X4 and am keeping the NP205 transfer case in the factory location using the 4L60 transmission. Here are the aprts I needed to make this work.
4L60 to 205
Here are some of those parts being installed(bottom first page)
And here is another thread showing more of that installation
The transmission must be disassembled to install the output shaft. I did not want to move my transfer case shifter or change my almost new driveshafts so this is the route I took. There are a couple of passenger side drop transfer cases that will mate to the 4L60 but I do not have the information on what works and what doesn't. If somebody has information on what works and how they handled the shifter etc I will be happy to include it. With all that being said I may still have driveshaft/transmission pan clearance issues due to being stock height. I will update with pictures when I know.
I am also going to try to modify my stock shifter linkage to work. Some say I won't be able to shift into first? Again I will update when I know.
Here are a couple of shifter linkage solutions
Lokar shift linkage
Lokar cable shift linkage
If you need to run a mechanical speedo with a 4L60 this is one solution
Shiftworks
The fittings on these 4l60/80 transmissions are not NPT but National pipe straight thread
And use fittings like these
Thealien is offline
Old 12-21-2009, 03:18 PM   #6
Thealien
Thealien's Avatar
Cooling
Here is some reading on cooling that will keep you busy. I will add more later I am tired of typing.
More than you thought there was to cooling
A couple of thread on an ebay aluminum radiator. If you conatct him he will add steam ports, change inlet and outlet sizes, you can even get them with fans!
Ebay Radiator
Ebay Radiator 2
His Ebay store
A fan install thread
Frugal fan install
Some hose adapters and steam port Ts Hose reducers etc. Look around this site a bit
JTR
Thealien is offline
Old 12-21-2009, 03:18 PM   #7
Thealien
Thealien's Avatar
Links to build threads
Calling all LS1 owners
Glocks build
LS1 into a 73
Ackattacks
69 Burb 5.3
Incredible HULK
Sicmaro
72BlazerCST
68 Short Step
Shifty
Killers 5.3
72 Shortbed 6.0
Super 73s 63 Chevy C10
68fleetsideC20 budget build
37 Ford lots of great fabrication and ideas!
Thealien is offline
Old 12-21-2009, 03:19 PM   #8
Thealien
Thealien's Avatar
AC compressor relocation options
THE EXPENSIVE ONES BUT???
A LESS EXOENSIVE SOLUTION BUT USES AN EXPENSIVE SANDEN COMPRESSOR
AND HERE IS THE THIRD OPTION
Cable X box for running a mechanical speedo from a VSS
Cable X
Power steering pump info
Use your old fitting on your new pump
Link to torque values
Scroll to the last 2 posts
Aeroforce technologies. Cool little gauge that plugs into your OBDII port and has lots of programable features!
AEROFORCE
Thealien is offline
Old 12-21-2009, 03:53 PM   #9
Thealien
Thealien's Avatar
Fuel system (any chance a mod can move this post up?)
The LS engines require 58-60 pounds pressure at the fuel rails. Older fuel rails had a regulator on the rails and there is a feed and return on these engines. On the later fuel rails there is only the feed on the rail. You need to have something like the filter regulator shown below to return the excess fuel to the tank. Some of the tanks these engines came with did this internally in the tank.
Corvette filter/regulator
I don't know how long this will last but a decent deal on the regulator/filter and he will take offers for less I am told
GF822
Lots of people use Walbro external pumps
Walbro external pumps and fittings
Dorman quick disconnects for GM fuel line
Dorman 5/16ths
Dorman 3/8ths
Russel AN quick disconnects
Russel 3/8ths
Russel 5/16ths
Don't have a way to make the GM quick disconnect? Try one of these
Dorman flare to quick disconnect
Fuel pump tank adapter
F-body LS1 fuel pump adapter kit
here is an installation tutorial of the adapter kit
Tutorial of adapter kit
Another gas tank modification
EFI pump tank mod
Dual tank info
Compliments of Glock35ipsc
Thealien is offline
Old 12-21-2009, 05:17 PM   #10
Thealien
Thealien's Avatar
Random parts/links
Brass fitting and adapters
LS engine pulling fixture
Happy Hooker
The last flaring tool you will ever need. Does the GM quick disconnects also and this is the best price I could find!
Mastercool universal flaring
GM Gen III & IV bolt and sensor list
Bolts and Sensors
There are not a lot of vacuum options on an LS manifold
Vacuum manifold
Some Vehicle Speed Sensor options VSS
VSS OPTIONS
Thealien is offline
