Old 02-22-2010, 12:23 AM   #1
americanmusc1e
americanmusc1e's Avatar
how hard to rebuild 4l80???
I put a 700r4 in my truck about a year ago and the transmission rebuilder that rebuilt it had to rebuild it several times again under warranty. He is really pissed off at me because he thinks I'm causing it to go out. Every time before it goes out it gets a wicked vibration starting at 3000 rpm then it takes out the front transmission seals, this last time burning up my 3/4 clutches. My rebuilder thinks it's the engine, but I'm almost positive its not. I'm pretty sure that it's in the converter that I got from Summit.................
anyway........my warranty is about up and I'm sick of 700r4's and I don't want to sink $1500 into another one.......I'm thinking about trying to rebuild a 4L80E with a manual valve body kit. How hard is it to rebuild the 4l80??? I rebuilt a 350 sbc and I can read a manual and follow instructions
any other ideas???
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 02-22-2010, 06:56 AM   #2
kenm78
Broken Down
kenm78's Avatar
Re: how hard to rebuild 4l80???
Just a bigger version. I helped rebuild 2 of them. Just keep everything neat and organized during tear down so it will make it easier going back together. Never modified one though. I don't think they are much harder than a TH350 IMO.
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 02-23-2010, 04:00 PM   #3
Myself
Don't forget the 4l80e will need a computer for shifting. They are pretty pricey.
Myself is offline   Reply With Quote
Old 02-23-2010, 04:46 PM   #4
americanmusc1e
I'm planning on using a stage 3 kit from transgo that has a full manual valve body.
http://cgi.ebay.com/ebaymotors/TRANS...e#ht_754wt_752
-- Josh
Old 02-23-2010, 05:53 PM   #5
clinebarger
Originally Posted by americanmusc1e View Post
I'm planning on using a stage 3 kit from transgo that has a full manual valve body.]
That kit is not for street use, Its not practical to have to shift the transmission everywhere you go. I thought you were going with a 2004R? Though a proporly built 700R4 should hold up to the power your making.
clinebarger is offline   Reply With Quote
Old 02-23-2010, 06:17 PM   #6
americanmusc1e
If I get a ratchet shifter It shouldn't be too bad, I don't mind hard shifts, It's like a manual transmission without a clutch
-- Josh
Old 02-23-2010, 06:25 PM   #7
clinebarger
As long as you know what your in for. Good Luck
Old 02-23-2010, 06:54 PM   #8
nomrlz
nomrlz's Avatar
a well built 700R4 or 4L60 will hold a decent amount of power. like said above. the 4L80 is a high dollar unit to use by the time you get the controller
nomrlz is offline   Reply With Quote
Old 02-23-2010, 09:42 PM   #9
Pyrotechnic
Pyrotechnic's Avatar
I think you just need to find a different transmission guy.
700R4's can handle lots of power, but the trans only ends up as strong as the guy has skill to rebuild them. Also, the TV cable must be properly adjusted, and the bracket must have the correct geometry. It doesn't hurt to initially hook up a gauge and check the line pressures while driving to verify that everything is adjusted and working properly with that expensive of a transmission.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
