03-10-2013, 01:05 AM | #1 |
TORGUE CONVERTER questions!!!
i am about ready to bolt up my th350 to my 283 i got the flywheel on. i was curious how to manully turn over the motor to bolt the torgue converter bolts, and which way does the torgue converter bolts go or does it no mater. i just rather no then not no.
any adivce in great. Lukas |
03-10-2013, 09:53 AM | #2 |
Senior Car Nut
Re: TORGUE CONVERTER questions!!!
I have a flywheel turner now, but for years just used a big screw driver
http://www.summitracing.com/search/d...-turning-tools there are cheaper ones out there, try Harbor Freight
Larry |
03-10-2013, 10:15 AM | #3 | |
The proper tool is the best way, but it can be done with-out one. In either case, taking the spark plugs out makes it a lot easier.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
03-11-2013, 08:59 PM | #4 |
I'm about to do the same thing and its my first time. I was told a good way is to put some longer bolts in the three holes in the harmonic balancer and put a big closed end wrench around one and push or pull up against another bolt. Also agree with longhair take the plugs out.
Williamsboy |
03-11-2013, 09:18 PM | #5 |
I use my hands....doing it slow so the compression bleeds out...
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
03-11-2013, 09:24 PM | #6 |
bump the starter...
03-11-2013, 10:31 PM | #7 | ||
"I ain't nobody, dork."
With the balancer off...
With the balancer on (sorry, small pic) Then all you need is a 1/2" ratchet to turn it. Gary
03-12-2013, 04:14 PM | #8 |
flywheel wrench and the convertor bolts go with the nuts to the convertor
Tags |
283, bagged, c10, chevy, th350 |
