03-14-2014, 10:38 AM | #51 |
Re: Porterbuilt Stage 1 Front and Rear Kit Chart
muckyp, I had clearance issues with the lower control rubbing/interfering the inner rally wheels and wheel balance weights. I also had to clearance/grind the tie rod area of the drop spindle. For my application, a grinder was my best tool until I decide to buy larger wheels. Im running my stock rally wheels which are 15x8. I used the belltech 3 inch drop spindle, stock lower control arms, & the air bag in the lower control spring pocket. I also used a PB stage 1 lowering kit which relocated the shock mounts. i hope this helps.
03-14-2014, 11:57 AM | #52 | |
Enjoy! - Matt
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
03-14-2014, 10:25 PM | #53 | |
70 SWB 454/TH400 |
03-15-2014, 05:10 PM | #54 |
I trimmed them with a sawzall & cut-off wheel, then cleaned it up with my grinder.
03-28-2014, 08:26 PM | #55 |
Just wondering how much lower (if any) having tubular control arms would make it?
I ask because the way the bag mounting happens with the stage 1 kit it brings the mounting surface flush with arm and not recessed into the cup. Would a set of porterbuilt tubular arms/CPP arms in standard form change those dimensions and make it lower again in the front? |
03-30-2014, 11:59 AM | #56 |
Thanks for the chart Matt... Awesome lay out for everyone to use as a comparison when building their trucks... I see you're in Lyman S.C., I'm originally from Columbia.
03-30-2014, 07:48 PM | #57 | |
You're welcome. Small world!
03-30-2014, 09:18 PM | #58 |
Does anyone have any pictures of how and where all the air valves and controller is mounted? Just looking for ideas on how to plumb and set up.
03-31-2014, 09:09 AM | #59 |
Here are some pictures of my air management set up which is Pro Performance's Pro 2 kit. I mounted my valve block, relays, & power distribution block on the cross member that's just behind the axle. The tank is mounted on a 2x2 that spans the rear of the frame where the original rear cross member used to be.
03-31-2014, 09:13 AM | #60 |
I don't have any pictures of the AVS controller but here's one of my gauges inside the cab.
03-31-2014, 09:53 AM | #61 | |
- Travis |
03-31-2014, 10:07 AM | #62 | |
04-02-2014, 01:08 AM | #63 |
Truck looks good. I like the way it looks That's the setup I'm going to put on my c10. What size tires do you have??
04-03-2014, 01:21 PM | #64 |
Thanks for the chart. I asked about this about a year ago and this is exactly the information I was looking for. I see in the first few photos you are at 80 psi front and 40 psi rear, but in the last few you list ride height at 60 psi front and 25 psi rear. Is that where you have always kept the ride height, or have you reduced it over time to fine tune the firmness you were after?
04-03-2014, 09:11 PM | #65 | |||
Clemsonteg - Be sure to check out the link to the Upstate GM Trucks Club that's in my signature. We've been getting together about once a month and we had 35 trucks show up in March.
04-03-2014, 10:33 PM | #66 |
Matt- thanks for the heads up. I've seen the pics in the regional forum. I definitely want to make it out, I just recently got the front end back on the my truck and got it back on the road. Once I get the kinks worked out I'll feel better about driving it to greenville.
04-16-2014, 02:47 PM | #67 | |
04-16-2014, 03:50 PM | #68 | |
The 4th pair of pictures is aired all the way up, the 6th pair is at ride height, and the 7th is aired up. Hope that helps. - Matt
04-17-2014, 01:03 PM | #69 |
