Old 07-02-2016, 08:45 PM   #51
projectking
projectking's Avatar
Re: '68 C30 Cummins swap
P.S. Don't knock me for the red accents that's how the dodge came.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 07-02-2016, 08:50 PM   #52
j_cst_10
j_cst_10's Avatar
Looks good, have you sorted out any of the clutch/transmission stuff yet?
j_cst_10 is online now   Reply With Quote
Old 07-02-2016, 09:06 PM   #53
projectking
Not yet, that's for tomorrow. I saved a piece of the clutch pedal and the piece that holds the slave to the firewall, I also want to get the throttle squared away.
67 Chevy C10 LWB
90 Mustang Gt
Old 07-02-2016, 09:54 PM   #54
j_cst_10
j_cst_10's Avatar
For the throttle I used a dodge pedal and cable assembly than with some tinkering was able to use the chevy plastic pedal on the dodge bracket assembly to make it look original (the foot portion of the dodge pedal is much smaller)
Old 07-02-2016, 10:00 PM   #55
projectking
I have the dodge pedal assembly that I plan to use with a special pedal. I took anything from the dodge that was different from the GM stuff just in case....
67 Chevy C10 LWB
90 Mustang Gt
Old 07-02-2016, 10:03 PM   #56
projectking
How tall is your fan blade? It looks to be smaller than mine and I'd like one that would be lower than the radiator, I read somewhere that the 6.2 Detroit blade will works too.
67 Chevy C10 LWB
90 Mustang Gt
Old 07-05-2016, 09:10 PM   #57
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on your truck!
Ryan
1969 Chevy milk truck
Old 07-06-2016, 05:19 PM   #58
projectking
Thanks Ryan, it's been a fun project for sure!
67 Chevy C10 LWB
90 Mustang Gt
Old 07-07-2016, 04:16 PM   #59
j_cst_10
j_cst_10's Avatar
I have been driving my truck around unintentionally doing 1 wheeled burnouts all over town.
Not sure what you are using for a rear end but try and source a limited slip and a 3.55 gear set. I am using the factory C20 dana 60 open diff with 4.10's and it drives significantly worse than the dually it came out of with those gears.
Old 07-07-2016, 10:48 PM   #60
projectking
I have the Dana 70 from the dodge that has 3:54's ? In it, when I drove the dodge around it was pretty nice thru the gears. The Eaton is still under the truck but isn't wide enough to clear the bed, I've been procrastinating because I'm not looking forward to cutting off the spring perches.
67 Chevy C10 LWB
90 Mustang Gt
Old 08-06-2016, 12:36 PM   #61
projectking
Well it's either been too hot or I've been too busy for the truck. Pulled the Eaton HO72 out and mocked up the Dana 70. Perches should be in by Tuesday so I'll have to wait to get it bolted in.
One problem I have is the wheel isn't centered in the opening and I'm unable to start the steel floor conversion until it's perfect.
67 Chevy C10 LWB
90 Mustang Gt
Old 08-08-2016, 07:30 PM   #62
Dieselwrencher
I had to move my perches back but at that time I switched over to 4wd hangers because they were taller than the 2wd ones.
Ryan
Old 09-01-2016, 11:23 AM   #63
GET_FOCUSED
I picked up a 69 c30 dually this past feb. Have been picking away at it when i have time 2 kids and a fulltime job tend to take most of that haha, im doing 5.9 12v intercooled cummins and rear four link on bags , ill be looking foward to see more added to this post as the build progresses and ill likely pick your brain as my build goes along!
GET_FOCUSED is offline   Reply With Quote
Old 09-01-2016, 03:05 PM   #64
projectking
Nice! It was originally my plan to 4 link and bag it but I'm afraid it won't be high enough for work. Are you planning a build thread for yours?
67 Chevy C10 LWB
90 Mustang Gt
Old 09-04-2016, 03:23 PM   #65
projectking
I was able to get the manual master out and start fitting the slave cylinder mounting bracket to the pedal assembly. I also did a test fit of the power brakes to see how the intake piping will need to be modified.
67 Chevy C10 LWB
90 Mustang Gt
Old 09-26-2016, 07:33 AM   #66
projectking
Got the slave cylinder installed
67 Chevy C10 LWB
90 Mustang Gt
Old 09-26-2016, 09:33 AM   #67
projectking
67 Chevy C10 LWB
90 Mustang Gt
Old 09-26-2016, 09:40 AM   #68
j_cst_10
j_cst_10's Avatar
Looking good. You will have to make a new rod. I could probably measure mine to save you the hassle so your clutch actuation works right the first time.
Old 09-26-2016, 11:03 AM   #69
projectking
That would be great, thanks.
67 Chevy C10 LWB
90 Mustang Gt
Old 10-01-2016, 09:57 PM   #70
Theboatandcarman
awesome build! everything is coming together nicely
Theboatandcarman is offline   Reply With Quote
Old 10-02-2016, 03:50 AM   #71
projectking
Thanks, I just wish work wasn't so busy or I'd be driving it by now!
67 Chevy C10 LWB
90 Mustang Gt
Old 10-09-2016, 07:53 PM   #72
projectking
Did some digging and found this on a dodge forum:
The MINIMUM travel of the slave cylinder push rod needed to actuate the clutch properly is 23-24 MM.
67 Chevy C10 LWB
90 Mustang Gt
Old 11-26-2016, 07:08 PM   #73
projectking
By the time I get home from work there's roughly an hour of daylight left to work on it so it's been slow going.
During the past couple weeks I was able to get it wired, hook up the power steering hoses, and finish the piping. I used an old 6637 for mock up by cutting down the dodge intake tube and a piece of 4" exhaust pipe. The intercooler piping is in stock form on the passenger side and modified to clear the booster on the driver.
67 Chevy C10 LWB
90 Mustang Gt
Old 11-29-2016, 07:25 PM   #74
Dieselwrencher
Nice work on it. It's looking great.
Ryan
Old 11-30-2016, 12:17 AM   #75
OutlawM92
OutlawM92's Avatar
Very nice! Can't wait to see her when she's finished!
1969 C10 "Problem Child"
1981 C20 CCLB "Nightrain"
"A good plan violently executed right now
is far better than a perfect plan executed next week.
Accept the challenges, so that you may feel
the exhilaration of victory."
OutlawM92 is offline   Reply With Quote
