Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 60-66
Old 10-17-2016, 08:59 PM   #1
Drummer29
66 chevy 3/4 ton project need help
I have a 66 chevy project have to replace cab do to a lot of rust.. but i have been looking for anything to help I need to know if a 64 chevy cab will work on a 66 chevy frame some stuff doesn't line up but other stuff does.. any ideas?
Drummer29 is offline   Reply With Quote
Old 10-17-2016, 10:17 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: 66 chevy 3/4 ton project need help
Should fit right on there. What doesn't line up?
DPowers is offline   Reply With Quote
Old 10-17-2016, 10:56 PM   #3
Drummer29
I just found out it's. C60 model which those are wider
Old 10-18-2016, 03:53 PM   #4
DPowers
DPowers's Avatar
Cab or frame is C60? Any pics?
Old 10-18-2016, 06:51 PM   #5
Drummer29
My frame is a c25 model 3/4 ton the cab I just bought ended up being from a c60 model 1964 2 ton truck (my truck is the green cab and the 2 ton is orange)
Old 10-18-2016, 09:51 PM   #6
DPowers
DPowers's Avatar
Not an expert by any means, but I do know the C60 inner fenders mount somewhat differently and are about an inch shorter than the C10/20 ones. Attached is a pic of a '61 C60 cab that shows the same inner fender mount. I was under the impression that the actual cabs were pretty much the same. Which cab do you want to use?
Old 10-18-2016, 11:06 PM   #7
Drummer29
That's what I was under the impression. The c60 apparently are wider. The front cab mounts on the c60 mesasure from center whole to center whole about 50 inches. The wholes on my cab are about 40 some inches... looks like I'm going to need to cut he c60 up and use its floor and modify to fix my cabs floor I haven't quite set it on the frame yet tho
Old 10-18-2016, 11:08 PM   #8
Drummer29
The 64 through 66 cabs are matches but apparently only between c10-c20 models they bolt with no issues
Old 11-22-2017, 07:51 AM   #9
Desy180
Hello! I'm not an expert in all this yet, but I'm interested in such questions. I esteem your opinions, I think it will come in handy.
Desy180 is offline   Reply With Quote
64/66 cab, compatibility, frames, repair
