Old 12-22-2016, 06:18 PM   #1
doubleds19666
doubleds19666's Avatar
Post 2010 L99/6L80E swap into 95 C1500 Silverado
Finally pulled the trigger on doing an LS swap and wanted to share the build. I hope any or all of this information may help someone else.
doubleds19666 is offline   Reply With Quote
Old 12-22-2016, 06:24 PM   #2
doubleds19666
Re: 2010 L99/6L80E swap into 95 C1500 Silverado
Here is a snapshot of the odometer prior to pulling the 5.7L and 4L60E that was in the truck.
Old 12-22-2016, 06:26 PM   #3
doubleds19666
The view under the bonnet before the swap.
Old 12-22-2016, 06:33 PM   #4
doubleds19666
Out with the old... she ran just fine, but it was a nickel and dimer.
Old 12-22-2016, 06:36 PM   #5
doubleds19666
As you can see, it was time for a cleanup at the very least.
Last edited by doubleds19666; 12-22-2016 at 06:38 PM. Reason: Forgot to attach the picture
Old 12-22-2016, 06:44 PM   #6
doubleds19666
Here is the donor powerplant. It is a 6.2L, L99/6L80E from a 2010 Camaro SS with a little over 14K miles.
Old 12-22-2016, 06:48 PM   #7
ls1nova71
ls1nova71's Avatar
Well that should really wake her up! Good luck with the swap.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-22-2016, 07:00 PM   #8
doubleds19666
This was my first experience with any wrenching on an LS. I will never go back! The pictures here are of disassembly to prep for the oil pan kit from BRPhotrods. I labeled all the connectors due to my noobness and snapped pics of all the ground terminals and their placement for the reinstall later down the road.
Old 12-22-2016, 07:01 PM   #9
doubleds19666
ls1Nova71, she is really awake. The truck is done, just trying to get caught up on all the build thread...
Old 12-22-2016, 07:07 PM   #10
doubleds19666
A few more pics of the disassembly for the oil pan replacement.
Old 12-22-2016, 07:14 PM   #11
doubleds19666
Here is the oil pan kit from BRPhotrods. Had to buy the Hummer H2 pan with the VVT machining. There was a valve in the old pan that I had to install in the new one. It was shipped with just a plug, not mentioned in the instructions...
Old 12-22-2016, 07:19 PM   #12
doubleds19666
Prepped the engine bay. You will notice the coil spring on the floor. I dropped the lower control arms to get access to the engine mount bolts. I used the engine and transmission mount kit form BRPhotrods also along with the mid-length headers they offer.
Old 12-22-2016, 07:35 PM   #13
doubleds19666
Needed to delete the external oil cooler, so bought a block plug and installed. Also installed the BRPhotrods motor mounts. I installed the mounts on the block backwards to leave the block farther forward first. Then I could safely re-chain the engine hoist to the front only since I had a crossmember to support the transmission in the back. More work, but I felt safer doing so with the investment money for the swap.
Old 12-22-2016, 07:40 PM   #14
doubleds19666
Here it is mounted correctly.
Old 12-22-2016, 07:43 PM   #15
doubleds19666
Here is the transmission crossmember mounted.
Old 12-22-2016, 07:46 PM   #16
doubleds19666
Only one spot on the trans tunnel that needed some relief with the 6L80E. It is right at the lower spot weld seam on the firewall.
Old 12-22-2016, 08:04 PM   #17
doubleds19666
Here she is going back together. Just the intake and coil packs for now until more parts come in.
Old 12-22-2016, 08:07 PM   #18
doubleds19666
LSbrackets power steering and alternator kit came in. Here it is installed. Later in the thread there will be pictures of the custom power steering hoses.
Old 12-22-2016, 08:11 PM   #19
doubleds19666
Since the tailshaft has the flange yoke I had to order an adapter from Gforce Engineering to mate the Spicer flange yoke U-joint adapter. Installed to verify fit.
Old 12-22-2016, 08:21 PM   #20
doubleds19666
Old fuel tank came out for a new setup. New tank, new sender, new in-tank fuel pump, new filter/regulator and hose kit from BRPhotrods, etc. The internal pump is Aeromotive and loud-ish, but much more quiet than an external pump. Had to use inverted flare o-ring to AN style adapter fitting on the sender for the new lines.
Old 12-22-2016, 08:28 PM   #21
doubleds19666
Running a Speed and Performance coolant temp sensor adapter for the instrument gauge at the moment, but a word to the wise... at idle I calibrated it based on the ECM temp by putting a resistor in series, but while driving enough air passes over it to cause the gauge to read 30 degrees too low. I will keep you posted on the resolution. Already have planned to purchase a 98 Camaro/Firebird LS1 ECT sensor with the 3-wire connector to replace the stock 2010 L99 sensor in the block. (This is the last hurdle to getting the stock gauges all to read correctly)
Old 12-22-2016, 08:31 PM   #22
doubleds19666
This is the reason why stock manifolds won't work. The flange rests on the frame very close to where I cut it out once already for the old long tubes from the original Gen III engine.
Old 12-22-2016, 08:41 PM   #23
doubleds19666
The BRPhotrods mid-length headers were the first headers I EVER installed that took no special tools AND had no clearance issues. These things were made for this engine in this truck.
Old 12-22-2016, 08:44 PM   #24
doubleds19666
Went shopping at the local parts store to find the radiator hoses needed for the job. Here is what I came up with... The upper radiator hose was swapped end to end after installing the air cleaner later in the build.
Old 12-22-2016, 08:51 PM   #25
doubleds19666
Removed the intake and installed another adapter from S&P for the oil pressure gauge. Also installed the transmission cooler adapter fitting and the transmission line adapter fittings to run -6 AN hose left over from the fuel line kit. Installed the brake booster sensor too to keep the swap close to stock for the engine.
6l80e, c1500, l99, ls3, swap
