03-28-2017, 10:26 PM | #26 |
Re: How i converted my '72 to Hydroboost for $35! (Lots of pictures)
So now it was time to plumb it. I dumped my pile of hoses on the work bench and started measuring and figuring
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust |
03-28-2017, 10:29 PM | #27 |
I ended up using the feed line from pump to booster from the 2005 Chevy 2500 i pulled at the junkyard. it required no modifications. this line was all metric.
03-28-2017, 10:31 PM | #28 |
It is always a good idea to blow out junkyard lines. A plugged line can cause all kinds of trouble
03-28-2017, 10:35 PM | #29 |
I used the late 80's 1 ton line for the feed back to the steering gearbox . I cut off the metric nut on the gearbox side and slipped on a standard fitting, then double flared it.
03-28-2017, 10:40 PM | #30 |
Then i grabbed the mid 70's T-fitting and made up a line for my steering gearbox return. keep in mind when running your return you want the least amount of bends as possible, and you want your bends gradual.the more bends,the hotter the fluid gets. A Steering fluid cooler is another option you may consider. I decided not to run one at this time.
03-28-2017, 10:48 PM | #31 |
The finished product. I won't be able to try it out till the engine swap is done. Make sure to bleed your power steering!
Total cost: $35 Feel free to add info to this thread!
03-31-2017, 09:28 AM | #32 |
Wow, nice thread that will come in handy for a number of people. Nice work!
04-04-2017, 05:22 PM | #33 |
Good job and write up. I may do something similar one day.
"Life is too short to drive a boring vehicle". Later, Wayne |
04-18-2017, 04:41 PM | #34 |
great info and pictures.. Also just for some info the 87-91 blazer/ suburban gear boxes are metric threads so you can use the hoses from the newer model trucks with no mods if the length is right
12-23-2017, 01:50 AM | #35 |
So you ran your original master cylinder from your factory booster c10 c20 c30 ? It’s been working just fine like that. I have a c10 but I’m running the c20 booster thought it would better braking but not much.
05-03-2019, 10:07 AM | #36 |
Any updates on how it works?
08-22-2019, 10:41 AM | #37 |
great writeup, thanks!
08-24-2019, 01:30 PM | #38 |
BlahBlahBlah
Last log in by OP March 2017. Hope the brakes held up!
10-17-2019, 09:35 AM | #39 |
Damn, i like this thread, wished he was around to ask some questions. I need to go to this due to vacuum issues. Great write up though
10-17-2019, 01:50 PM | #40 |
What was your question?
11-13-2019, 08:51 AM | #41 |
Great write up and good looking job.
08-20-2020, 10:48 AM | #42 |
Great write-up. Thanks for all the pictures and info. Looking to do this soon.
72 K5 4x4 350 70 Nova 454 5spd 4-link |
08-20-2020, 10:59 AM | #43 |
What a great write up, wonder what happened to the thread starter?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Tags |
hydroboost, hydroboost swap, ls swap |
