Big hub Dana 44 blue locking knob repair
The donor axle I am rebuilding has the nice blue locking knobs. Sadly, there were some issues with the hubs and the PO apparantly used pliers to lock and unlock the hubs, until they cracked inside where the pin goes through.
This seems to be a common issue, after searching around, I found a post on another forum that led me to doing this repair. I have a wood lathe, but you could probably use a disc or belt sander, or even some files and a hack saw to do this. I took one of the knobs to the hardware store and searched through all the plumbing fittings until I found a piece that I could 'turn' on my wood lathe down the right ID size and that was thick enough to have plenty of sidewall to not break in the same spot as the knob. I took a picture of the part number, but many parts will probably work. At home I took some measurements, then turned down the piece until it fit snugly inside the knob. Then it parted it off, or cut it to length. Note that in the pictures the piece is a little too long - it ended up hitting the stub axle and I had to grind it down later. This part does not have to be extremely precise, it just needs to give you 2 new anchor points for the pin that are in the same place as the original, and stay put. Next i took my dremel and cut random crosshatch grooves in both parts, so that he epoxy will have lots of space to lock onto so that the new plastic piece cannot move. I used some standard 2 part epoxy and let it dry 24 hours. After dry, just drill new holes through, reassemble and there you have it.
1968 GMC 3/4 Ton 4x4 K20 / 2500 1971 Chevrolet Chevelle Malibu Last edited by Old_iron; 06-25-2018 at 10:00 PM. Reason: Fix photos |
Re: Big hub Dana 44 blue locking knob repair
More photos:
1968 GMC 3/4 Ton 4x4 K20 / 2500 1971 Chevrolet Chevelle Malibu Last edited by Old_iron; 06-25-2018 at 10:01 PM. Reason: Fix photos |
clever, thank you for posting
I started out with nothing - and I still have most of it |
Yes, very clever. All I ever did was re-drill new holes where there was meat and stick a drill bit through
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Very clever, thanks for sharing it
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Moderator
![]() Join Date: May 2007
Great tip! My K2500 has oem blue dials with perfect faces, and broken pins.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Someone should machine steel inserts to eliminate this problem from ever occurring... for those who don't maintain or lube hubs properly
SWB 4x4 Collector
![]() Join Date: Jun 2001
Someone is making reproductions now.
https://www.ebay.com/itm/CHEVY-GMC-4...oAAOSwlJlaoBFW
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Tags |
dana 44, hub, knob, repair |
