10-19-2018, 03:46 PM | #1 |
Plug Wires
im going to relocate my coils to the back of the engine...for those that have done this what are the better ones to use..im guessing there are some kits for this...id like to use 10mm wires if possible
10-19-2018, 11:37 PM | #2 |
Re: Plug Wires
D7I used an 8mm Taylor cut to fit set made for an LT1. The LT1 has the same ends on the Optispark as an LS coil, unlike the older HEI wires. Depending on how you mount your coils you may need either straight or 45* ends. The Taylor numbers are 46052 for the straight and the 45 deg version is 46069.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
10-20-2018, 01:31 AM | #3 |
Re: Plug Wires
Thanks Eric !!....I'll check them out....I had forgotten about taylor...
10-20-2018, 09:45 PM | #4 |
Re: Plug Wires
I used MSD 8.5's. The kit I got was LS specific and came with either 90's or a straight/multi angle up to roughly a 45 degree for the plug side. I believe only 45's for the coils, but cant remember for sure now. Havent ran it yet, but i like them based on looks.
10-20-2018, 10:10 PM | #5 |
Re: Plug Wires
Thanks sprint..those look good..
10-21-2018, 07:28 AM | #6 | |
Re: Plug Wires
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-21-2018, 08:11 AM | #7 |
Re: Plug Wires
Zep..that intake looks just like the one I have..If so its a holley 300-137....you would also need the Holley fuel rails....dayj1 did a great job on his and I'm kinda following what he did..http://67-72chevytrucks.com/vboard/s...ght=Skin+a+cat
