![]() Join Date: Mar 2003
Worth messing with?
Got a call about a 1990 4x4 flatbed for sale. 1 ton, 454, auto. Find out it is a light duty 1 ton (8600lb gross). Converted to dually with spacers. Has a tilt bed. 195k on the speedo, will not pass the smog nazi inspection. Couple of low compression cylinders. Needs interior work, pretty much trashed being a contractors truck. Trans was supposedly rebuilt about 2 years ago (T400). Engine partially apart, but not too far. I can get to my house for 600 including towing. I'm on the fence on this one............worth it? Thinking about maybe parting it
#2 | |
Questionable
Re: Worth messing with?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
driving is in my blood
The big block is worth $600 by itself if you part it.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
It won't have good heads (less they were swapped) but the lower end is the same as older big blocks. I had 2 TBI454s that year range and ran awesome. Nothing special, but I'd get it. I want another one lol.
Been thinking more about picking it up and parting it. Just have to find the time to disassemble and stash parts away
At 8600 gvw, it’s probably a 3/4 ton
Being a 90 it won't be an HD, they didn't come out till 91.
6000-6200 gvw, 1/2 ton
7200 (f44 rpo) 1/2 ton 7200 light duty 3/4 ton 8500-8600 3/4 ton 9200+ 1 ton The 3500hd trucks aren’t 1 ton. They are 15000 gvw. Either way, it sounds like it may be worthwhile. In my opinion, the amount of rust would be a deciding factor. |
#11 | |
#12 | |
For instance, a light 3/4ton uses the same brake caliper as a heavy 1/2. A light 1ton uses the same caliper as a heavy 3/4ton.
A light 1 ton (3500) is a single rear wheel @ 9,200 GVW. The dual rear wheel 1 ton (3500) is 10,000 GVW. The 8,600 GVW is the 8-lug 3/4t (2500) and the 7,200 GVW is the 6-lug 3/4t (2500) with 14-bolt semi-floater. The 7,200 GVW 1/2t (1500) has the 14-bolt semi-floater.
