08-08-2020, 09:15 PM | #1 |
Carpe manana
Blazer and Jimmy Fuel Neck Styles
Surprisingly there are different styles. I thought I’d illustrate the differences with photos drawn from here on the forum. Feel free to clarify if anything is incorrect or add more to expound.
Here are examples of the 69-70 style...two-piece
08-08-2020, 09:16 PM | #2 |
Carpe manana
Re: Blazer and Jimmy Fuel Neck Styles
1971 - also a two-piece...I believe the upper part that attaches to the bedside is the same used on 71-72 pickup RPO NL2 aux fuel tanks.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 08-08-2020 at 09:21 PM. Reason: Added |
08-08-2020, 09:18 PM | #3 |
Carpe manana
1972 one-piece style...note use of a tie strap securing the vapor hose to the metal pipe above the floor pan
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 08-08-2020 at 09:37 PM. Reason: Added |
08-08-2020, 09:33 PM | #4 |
Carpe manana
I suspect all years made use of this bracket to support the fuel line and accompanying vapor line below the floor pan.
Non-CST K5s used the metal cover over the fuel neck. CSTs had the rear panels that served to cover the neck.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 08-08-2020 at 10:00 PM. Reason: Added |
08-08-2020, 09:38 PM | #5 |
Carpe manana
Options for replacement fuel hoses...
Gates 24702 w 1.375” ID https://www.jegs.com/i/Gates/465/24702/10002/-1 GM if it can be found.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 08-08-2020 at 10:07 PM. Reason: Added |
08-08-2020, 09:40 PM | #6 |
Great post!
08-08-2020, 09:45 PM | #7 |
Carpe manana
Thanks Dwayne. Fun stuff. You were an inspiration for the idea based on an old post of yours. Crazy that GM changed the style this many times.
08-08-2020, 11:07 PM | #8 |
All I can say is subscribed. It's too late for my brain to process all that.
08-09-2020, 08:25 PM | #9 |
Never realized that there were so many differences.
Where is the best place to find info on the pipe that goes next to the filler neck with the 3 small hose connections at the bottom? |
08-09-2020, 08:30 PM | #10 |
Carpe manana
Factory assembly manual is a good start plus photos from prior builds and part outs. I think there is some variation in tank plumbing for 72 compared with other years. Here’s an example diagram from said manual - I’ll post a pic from my 72 build.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 08-09-2020 at 08:38 PM. Reason: Added |
08-09-2020, 08:56 PM | #11 |
Carpe manana
Here’s an example of the most recent aftermarket iteration of the K5 fuel tank with the correctly configured neck.
(All borrowed pics, thanks for posting)
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 08-09-2020 at 08:56 PM. Reason: Added |
08-11-2020, 03:12 PM | #12 |
Thanks Deadhead, I appreciate it.
I dont have the evap canister so I am looking at options for simplifying all of the pipes, hoses and connections. The evap system seems a little excessive for such a primitive vehicle. |
08-11-2020, 10:40 PM | #13 |
Carpe manana
You bet. Good luck with your build.
08-11-2020, 10:53 PM | #14 |
Keeps getting better and better!!! Now, if you could do this with the whole blazer you would have something.
08-18-2020, 01:11 PM | #15 |
I believe the fuel filler neck and gas tank were the last pieces i took off during dissasembly. By that point i was so irritated with rusted out screws and bolts that i dont think i took the time to properly survey the peices i was removing.
Thanks for another great writeup on the year differences.
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858 |
08-27-2020, 04:32 PM | #16 |
Equal opportunity joke ofender
Apparently the 72 fuel neck is available aftermarket now as well (not mine)
https://www.ebay.com/itm/1969-1970-1...cAAOSwuSxfMwAk .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
08-28-2020, 07:54 AM | #17 |
Carpe manana
Wow. Thanks for posting.
09-23-2020, 09:08 PM | #18 |
Carpe manana
Really useful photo taken by member PDXk5 that illustrates where the hose clamp goes on the splash shield and tie fastener location.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 09-23-2020 at 09:10 PM. Reason: Added |
09-29-2020, 02:36 PM | #19 |
Great post......getting ready to put my Blazer in the shop for a complete maker over.........recently bought the new tank shown above so just bought the filler neck off ebay in link above from the TruckStop....
Thanks for the info fellas!
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC |
09-29-2020, 03:10 PM | #20 |
That is the came tie strap that 71 big block Chevelles use on heater/AC hose near the alternator.
09-29-2020, 03:11 PM | #21 | |
Look at that red primer. Where was that truck assembled?
09-29-2020, 05:09 PM | #22 |
Carpe manana
That's original paint peeking through the mastic undercoating. I'll dig for more pics of Jeff's Blazer - I think it has a single wall top so should be Flint assembled.
09-29-2020, 11:51 PM | #23 |
Yep. Original 514 paint with an undercoating that was applied when my father-in-law bought it new in 1972. Flint assembled rig. Yes, it has its original single wall top. The hatch was in excellent shape too, until I forgot it was up and pulled out of the garage a couple of years ago. It broke the hatch handle off and jacked up the hatch. Here are a couple of photos of it from last summer. Handle has been replaced since then and hatch looks OK from 5 feet away but still needs to be restored.
09-30-2020, 07:22 AM | #24 | |
Carpe manana
Jeff - thanks for the photos
09-30-2020, 10:19 PM | #25 | |
So, you guys piqued my interest and I did the string wrap method to trace the OEM tie to determine the length. I didn’t want to ‘unzip’ it to avoid it breaking from fatigue or what not. Anyway, I measured the tie from the tip of the ‘loose’ end to the tip of the closed loop end and got 11 inches. Hope that is of use to you guys. Is there a source for correct style OEM ties offered in different lengths? I’m planning on replacing my original fuel tank with one of the correct repro styles from above, as well as new fuel lines. Was thinking I would/could fish the old lines out and the new lines into the metal strap and plastic tie but if the plastic tie breaks it would be good to know where I could get a correct style replacement. I’m going to be installing a fuel skid plate I recently had powder coated under the tank after the fuel tank is installed. I’ll start a new thread for that endeavor but could use some pointers on that as I tackle that later this winter. |
