09-30-2021, 09:13 PM | #1 |
Hard Brake Lines 3/4 Ton Drum/Drum
I’ve reasearched and haven’t found a definitive answer: can/should I run 3/16 brake lines on a 3/4 ton to drum/drum setup? Obviously stock lines are 1/4 and my intuition is that 1/4 is preferred to flow more fluid volume to fill the wheel cylinders.
Is the output port size on the prop valve/distribution block a limiting factor?
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
09-30-2021, 09:33 PM | #2 |
Re: Hard Brake Lines 3/4 Ton Drum/Drum
I'd go with what the factory engineered and installed
