06-15-2022, 08:40 PM | #1 |
low n' slo
front end gaps
truck is a 67 suburban. i went with some grant hinges way back when because the stock hinges had to go for the air ride. after figuring a way to get the hood struts mounted, the hood sits a little too far forward for my liking. i installed new hood bumper stops in the front and those need a little adjustment as well. i know the gaps were terrible from the factory....and im not building a show truck by any means. but would this be "acceptable"? lol. the thing bothering me most i think is the cowl gap. i do have the cowl to hood seal that will help hide it some.....but not sure since its not on. all the panels still need some tweaking like the doors and cowl panel for sure....
what to do? the hood has absolutely no adjustment.....
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
06-15-2022, 08:41 PM | #2 |
low n' slo
Re: front end gaps
few more
06-15-2022, 08:42 PM | #3 |
low n' slo
Re: front end gaps
the cowl isnt bolted down at all, just sitting there. i did buy new fender shims but not really sure if they are needed. passenger side seems like they should be needed? im not good at all at lining up body gaps but i would like to at least get them decent
06-15-2022, 10:16 PM | #4 |
Re: front end gaps
I'm not familiar with the hinges you speak of, but how can they have no adjustment?..are the holes not slotted?.. the hood definitely needs to move back
06-15-2022, 10:31 PM | #5 |
low n' slo
Re: front end gaps
you can see some up close pictures in this other members build thread.
http://67-72chevytrucks.com/vboard/s...=365912&page=2 they are made to weld on the hood and the bucket welds inside the cowl section, although he made his bolt in...which I did not. the hood has to come out anyways eventually to clean and paint the underside. I'm wondering if I can maybe section the arm a bit, weld it back together to suck it in?
06-16-2022, 06:56 AM | #6 |
Re: front end gaps
If the holes where the hood bolts go were slotted , would that help?
Hard to believe they'd build and sell something like that with 0 adjustment
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 06-16-2022 at 07:04 AM. |
06-16-2022, 07:06 AM | #7 |
low n' slo
Re: front end gaps
yup that's what I get for buying $80 hinges. they are completely weldnon no bolts at all. that link I posted, the guy made his use bolts, which I wish I would've done.
the only way to slide it back is to shorten the swing arms but cutting them and rewelding them, or maybe cut off the top mount ears and reweld them back a little. I think I'm too deep in to ditch the whole setup and go porterbilt
06-16-2022, 10:21 AM | #8 |
Re: front end gaps
so, its welded to the hood and the firewall ?
and no way to adjust that seems like a really odd way to do it... margin for error is very small... even if you cut and section, its still a crap shoot on wether it fits right even after doing all that
06-16-2022, 10:29 AM | #9 |
67-72 parts collector,…
Re: front end gaps
Cut your losses and buy some good hood hinges.
06-16-2022, 12:38 PM | #10 | |
low n' slo
Re: front end gaps
well, if i went that route i would at least be left with patch panels to cover up the current brackets. but im more worried about trying cut the welded on brackets off the hood without damaging the hood.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 06-16-2022 at 12:46 PM. |
06-17-2022, 04:48 AM | #11 |
Re: front end gaps
I dont think I'd be trying to close up the cowl gap by welding a rod to the back of the hood...that could turn out even worse..
I'm not sure what would be involved with trying to fix it.. Just from what I can see in the pics, I think I'd cut the hood loose from the hinge and fix it so it could be bolted to the hinge, then you would at least have a way to adj it some
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 06-17-2022 at 07:00 AM. |
06-17-2022, 06:53 AM | #12 |
low n' slo
Re: front end gaps
I'll get some pictures when I get home from work....I think I'd destroy the hood cutting it loose.
trying to save a few bucks is either gonna cost me good gaps or cost me another $800 or so for some new hinges and a different hood
06-17-2022, 04:33 PM | #13 |
low n' slo
Re: front end gaps
heres how the hinge welds in. it follows the back contour of the hood...which would make cutting it off, without damaging the hood, a pain in the ass
06-17-2022, 06:43 PM | #14 |
Re: front end gaps
Is the piece under the cowl welded as well?..I see bolts for the struts go thru the firewall..
I think you could cut the hinge off the hood...there just wouldnt be anything left of it
06-17-2022, 07:40 PM | #15 |
low n' slo
Re: front end gaps
yup that hinge bucket is welded in too. that plate for the struts is actually from a different company called switch suspension. I bought that to bolt to the firewall to strengthen it some, and to add a strut option. it's for their own hinge kit but I made it work for mine.
06-17-2022, 08:50 PM | #16 |
Re: front end gaps
What I think I would do...
make a pattern of the hood side of the hinge,...cut that sucker off..without damaging the hood.. make a new hood side hinge, one that will bolt to the hood with slots for adjustment.. That's about all I got
06-19-2022, 04:39 PM | #17 |
low n' slo
Re: front end gaps
after staring at this gap all weekend i just cant leave it alone. i think what i will do is buy the actual switch suspension hinge kit that goes with the strut upgrade kit i bought from them that is bolted on there now. ill have to cut the welded hinges off the hood and make cover plates where the current hinge pockets are on the firewall...but oh well. i think its better than to run the risk of shortening my current hinge arm and screwing something up.
live and you learn i guess....thanks for yalls input guys!
06-19-2022, 08:30 PM | #18 |
Re: front end gaps
Sounds like the best option.... keep us updated on how it works out
06-20-2022, 02:28 PM | #19 |
low n' slo
Re: front end gaps
will do. getting back to trying to get the truck wired and maybe get a windshield in it if i can find someone around here that knows how.
then ill get to whackin at this hood
06-26-2022, 02:27 AM | #20 |
Re: front end gaps
Maybe weld up the hole in bracket under cowl, adding some extra "meat" on the backside towards cab. Re-drill hinge bolt hole the amount hood needs to be moved back.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
06-27-2022, 10:59 AM | #21 |
Re: front end gaps
If it were mine I would cut here . Move it back till it lines up then tack it .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
06-27-2022, 11:50 AM | #22 |
low n' slo
Re: front end gaps
the issue with going that route is that bracket is completely welded in there, up to the firewall and on top of that cowl area. it's not just welded at the bottom
06-27-2022, 08:03 PM | #23 |
Re: front end gaps
I see it now.
06-29-2022, 11:59 AM | #24 |
Re: front end gaps
You could cut out a section of the piece that's attached to the hood and re-weld it.
06-29-2022, 01:45 PM | #25 |
low n' slo
Re: front end gaps
that was the idea I wanted to roll with but unsure if it effect the integrity.
