01-05-2023, 01:14 PM | #851 | |
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
John 3:16 - Saved me... God Bless |
01-05-2023, 01:15 PM | #852 |
Another idea to consider... sounds like the easiest so far. lol
01-05-2023, 01:17 PM | #853 |
Thank you sir. It has been some time to figure out but I really do not mind much. I like figuring out a solution to a problem and help others along the way if I can. Like alot of things, there are 100 different ways to make it work, finding the one that works for you me is the fun part. LOL
01-05-2023, 02:46 PM | #854 |
I didn't use an aftermarket column but I did use a '71 Camaro tilt column and I modified the stock mount to hold the column. If you're interested the mod starts on post 528 on my build page.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
01-05-2023, 04:04 PM | #855 |
Thank you sir! I just went and looked at your build, page 528. I like the idea. I am using the Clutch bump stop though, but your idea does give me another idea though. Thanks again.
01-05-2023, 05:16 PM | #856 |
So here is a diagram of hose routing. Please do not laugh to hard at the drawung
01-05-2023, 07:02 PM | #857 | |
01-05-2023, 08:02 PM | #858 |
I bought the pressure reducer kit for my Hydroboost/Fox-Mustang-Rack install, but I'm going to run it as is first, to see whether it needs it or not. No point making more work for myself.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
01-06-2023, 01:12 PM | #859 | |
Again, thanks for the update. That helps too with routing!! You saved my butt Arne!!! thank you Jeff
01-09-2023, 12:21 PM | #860 |
Ok, so I got the steering rods, universal joints and heim joint installed, routed and completed, well for now until I do the tear down for paint. Once I got it worked out, it went together really nicely.
BUT Then I tried to fit the new Radiator support and new fenders onto the new inner fender wells. OH DAMN, the fitment sucked! The Rad support went on fairly easily at first... then after close inspection... ya not so well. There (as expected) alot of adjustments, cleaning burrs, hammer and dolly need, and such to get it to fit, but it really does fit now. The main issue was the damn lower Radiator support bushing! There was 1.5" gap where the two main rad. bolts and bushings sit! I bought the bushing mount kit for this and it was only about 1/2" thick, leaving 1" of open space, UNTIL I tried to install the fenders, and figured out that the inner fenders need some persuading.. But, after test fitting the old fender I found that most of the issue is with the inner fender, not outer fender. Anyways, after some slight adjustments with the inner fender... they all mounted up rather nicely and the Rad support bushing kit worked great... now! LOL
01-19-2023, 10:57 AM | #861 |
Well I have some updates to post here tomorrow. Got the fenders finally mounted mostly, look great, had some alterations needed but all good now. With that said, the damn radiator... what a pain... lol not really but when you go from stock smaller in all dimensions to much bigger, aluminum 3 row .. the stock lower mounts will not work. So I just bent up my own, got them looking good just need to be powder coated and then rubber attached. With that said, I am working on getting the radiator top mount in from LMC and then start the power steering / Hydro-boost line routing and power steering pump reservoir mount figured out.
BUT in the mean time I got a new "toy" to play with, a 1940 Chevy Master 85 Coupe that is about as far from stock as possible (fits me... lol) It is on a full tube chassis, 383 stroker, turbo 400 manual valve body, narrowed for 9", ladder bars, wheelie bars and rear tires that are just crazy wide = 31"tall x 18.5" wide x 15"! Tires are Bias ply with tubes and NOT cheap!! LOL anyways, I will post pics here tomorrow. My plan is to just get it up and running good to take to shows and continue on the "66. I just do not want to rush the "66 to finish... that never turns out well.
01-19-2023, 11:18 AM | #862 |
Congratulations that it worked. Great model, the coupe.
Nice also the progress on your Truck.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
02-13-2023, 10:58 AM | #863 |
I apologize that this is not about the "66 it has a connection to it in that the reason i am not on it is because of this, the 1940 Chevy Coupe I got as a "Gift from God".
As mentioned before i am getting this running good and very drivable now so that i have a show/play rig while i am building the truck. So anyways, i got to speak to the original builder of the car, Ronnie Vice in Alabama. The motor is a 383 cu in block .30 overbore, with Billet Splayed main caps, Eagle Steel Crank, Lunati Rods and Pistons, Hell Fire Rings, Victor Jr aluminum Heads and intake, Turbo 350 built to the teeth with shift kits and 3000 stall, Frod 9" Rear with 31 spline axles shortened and reinforced along with a Detroit Locker and 4.56 gears rotating 31"x18.5 x 15" DOT tires. He put more into the motor than i paid for the entire car he said. Unreal, but anyways, been working on the Brakes and such on it. I would post pics but not sure if that is ok to do here.
02-13-2023, 01:11 PM | #864 | |
02-13-2023, 02:37 PM | #865 |
I'm perfectly fine with a tantalizing pic now and then of whatever else you're working on other than the '66.
And you can't toy with us without leaving a tantalizing pic! (I mean, we're all "car guys" here...).
02-13-2023, 11:27 PM | #866 |
I agree with both Scoti and SkinnyG. You're welcome to post up a couple pictures here, or if you would rather do a whole build thread, the Alternate Tinkerings section is just the place for a whole thread.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-14-2023, 07:35 PM | #867 |
Just a couple pics of the 1940 Chevy Coupe I am playing around with as promised
03-14-2023, 07:37 PM | #868 |
"Capone" as I call it, has a big "ole Butt... lol Almost done playing around with this one. As mentioned earlier, i am just getting this one running and then i will get back onto the truck.
03-15-2023, 03:03 AM | #869 |
Capone is a cool old racing car, have fun with it.
03-16-2023, 10:25 AM | #870 |
Ya, always wanted that "old school" hot rod... Thanks
