![]() Join Date: Nov 2012
Oops, was I suppose to grease it?
So I have been slowly doing the ls swap in front of my sm465 and np 205, finally started the beast and it sounds like I have a dry pully in the clutch area,the clutch functions properly and the throw out bearing has proper clearance. The noise does not change when I push the clutch in or out, does seem to go quite the higher the rpms . last note is I may have neglected to grease the pilot bearing for the transmission,its a bearing and not a bushing but nonetheless I'm not sure whether I greased it or not for the snout of the input shaft,problem?.
#2 | |
Re: Oops, was I suppose to grease it?
#3 | |
I will snoop further |
Starter was just barely contacting flywheel, 2 starters to choose from a 9 toothe and 11, I used the starter from a automatic flywheel on my clutch flywheel and it is making contact at tip of gear,now you know.
![]() Join Date: Jul 2015
Glad you figured it out and thanks for posting the solution for the next guy!
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
