04-10-2008, 09:24 AM | #1 |
what am i looking for when i get a electric fuel pump
It will be sending fuel to a 600 cfm holley carb. what am i looking for? what do i need to steer clear of? suggested brands? regulator size? max/min psi? any other goodies ill need?
04-10-2008, 04:26 PM | #2 |
Re: what am i looking for when i get a electric fuel pump
My first suggestion is "don't" for a street engine.
After that, there's plenty of documentation on the manufacturer's websites on fuel system design. http://www.holley.com/data/TechServi...ech%20Info.pdf |
04-10-2008, 09:33 PM | #3 | |
04-10-2008, 09:54 PM | #4 |
Ah, I'm with you.
The biggest decision is if you're going to "deadhead" the pump (no return) or add a return as there isn't one on our trucks. If deadheading, you need to pick a pump that's made for that. The second issue is wiring - it's important to have an oil pressure switch. It'll take a while to get the details worked out, but it's not that big of a deal. It isn't cheap, unfortunately |
04-10-2008, 10:01 PM | #5 |
the p.o. moved the tank to under the bed, mabee the tank thats under there has a return line already. ill have to check that out.
04-11-2008, 04:42 AM | #6 |
driving is in my blood
I run carter street pumps that put out 5-9psi I believe. I ran a holley deadhead regulator for a couple years then converted it to return style and fabbed up a return line. Helps keep the pump cooler which I needed in 110* phoenix summers. I set the pressure at about 5.5-6psi for the edelbrocks and 7-9psi for holleys.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
