Barn Doors or Tailgate?
which ones are more desirable?
I like the barn doors, easier to load, but are their other pros-cons between the 2? |
#2 | |
Low & Fast!
Re: Barn Doors or Tailgate?
I know you don't see the barn doors as much and I think they looks cool.. I dont think that helped you did it.. ![]()
OL BLUU
![]() Join Date: Mar 2004
I personally like the tailgate look... it's a "cleaner" look IMO... and also the window rolls down. And the barn doors have the middle support in which blocks some of your view; when you look in the rearview mirror.
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
It followed me home?
Tailgate all the way. "Tailgating" is just not the same with barn doors
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 02-11-2010 at 07:27 PM. |
Slots go on anything!
I prefer the barn doors. You don't have to deal with the tailgate window getting stuck or not working. In the 89-91's you could get them with defrost, too.
Since you are in MO, you may want to try to find a 'burb with both rear heat and A/C. Rear heat is probably a lot more prevalent up there, and it works really well.
1974 Jimmy- 5.3/4L80e/NP241 |
I like the barn doors because I like to haul stuff and it easier to load. I agree with the window problems you can have with a tailgate.
#7 | |
Ditto. Incidently, by way of trivia, the barn doors were base (ie, "ZW9 - base body") and the tailgate was optional ("E52 - One piece liftgate with lift glass"). I'd say the tailgate option was definitely the high runner. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I agree with many comments before, it's a personal preference. I've owned 2 suburbans the first had a tailgate and the window didn't work very well. but it's a much cleaner look and have a better view without the barn door pillars in the way. My second suburban which I just sold had the barn doors and I do think make it easier to load. And I also agree find one with a removable rear seat and rear AC and heat controls.
Thanks all.. I think I like the barn doors for ease of loading/unloading.. and that is more important than looks at this point. I must be getting old!
I know the pieces fit
Absent of inherent problems, its pure personal choice. I'd put the rear access at the bottom of the list personally. When I found one perfect inside and out the way I wanted it, I wouldn't care which it had.
I have both and there is not really that big of a diff, i do like that my 4x4 has barn doors because of the ease of opening doors...If you wanted to lift yours any, I would say barn doors.
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
78K & 79C Jimmys
have had both, barn doors better for me,dog liked the window down but fumes would be bad at some speeds,around here just the tailgates(used) are a hard find.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Looked long and hard to find my burb in good shape with barn doors.I just like the way they look.
big old burb in primer.lot of work to do. |
