Old 05-09-2010, 11:52 PM   #1
billsbowtie
billsbowtie's Avatar
heavy duty ft sway bar & brackets off of a 73 3/4 chevy f/s
but will also fit the 1/2 trucks it's in good shape but i would replace the bushings while it's off they cost about 25 to $30. i will take $80.00 shipped for it .please reply in tread if interested .
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 05-10-2010, 11:34 AM   #2
skeeterbug
skeeterbug's Avatar
Re: heavy duty ft sway bar & brackets off of a 73 3/4 chevy f/s
do you know if it will fit a 71 model 1/2 ton that has been dropped 5" in front?
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 05-10-2010, 11:29 PM   #3
billsbowtie
i am not sure you may check with someone else that has did the same thing to there truck . and see if they are useing a stock swaybar.
Old 05-11-2010, 12:56 PM   #4
skeeterbug
skeeterbug's Avatar
billsbowtie, is that an 1 1/4 sway bar? just trying to see how much exactly what the bushings would cost me. if so ill take it zip 37184, just pm me later and we will work out the details.
thanks
skeeterbug
2013 best 7.39
2014 best-7.38
Old 05-11-2010, 03:28 PM   #5
michael bustamante
michael bustamante's Avatar
1 got 1 1/4 bushings from o reillies so theyre pretty readily available, I asked for a 78 chevy 3/4 ton 2wd. but the 3/4 tons came with 1 1/16th, 1 1/8 and 1 1/4 so measure carefully oh and mine fit well.
1967custom
michael bustamante is offline   Reply With Quote
Old 05-11-2010, 11:05 PM   #6
billsbowtie
skeeterbug i just notice i put the wrong year in the title it came off of a 72 3/4 ton it will still fit but i just wanted to let you know. i will measure it and pm you in a few mins. bill
Old 05-11-2010, 11:15 PM   #7
skeeterbug
skeeterbug's Avatar
cool thanks
2013 best 7.39
2014 best-7.38
Old 05-11-2010, 11:22 PM   #8
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Originally Posted by skeeterbug View Post
cool thanks
Skeeter, at one time i read about people not using the frame bracket, and mounting the bushing directly to the frame, thus taking like 2-3 inches out of the measurement on extremely dropped trucks, just a headsup on making it bolt up to a lowered truck.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 05-12-2010, 07:41 AM   #9
skeeterbug
skeeterbug's Avatar
walts, yeah ive heard of people doing that as well and since my truck has 5" of static drop in the front thats what i figured i will have to do.
thanks
skeeterbug
2013 best 7.39
2014 best-7.38
