Old 11-30-2011, 10:58 PM   #1
GMC"ER
Still working on the 69 GMC stepper! Just not satisfied with my tire size?????
Hey guys been a while since I have posted any pictures of the 69 GMC stepper just thought I would to see what you all thought of the progress so far? Have not had a lot of spare time to work on it. I am running a 215/70 R15 on the front with 7" rallies and a 235/75 R15 on the back with 8" rallies on back. And with 2 1/2 drop spindles and 3" drop springs up front 5" flip axle kit and 2" shackles in rear with a C notch kit and new drop shocks from CPP. Back some time ago I posted a question on tire size and now I am going to change the back to a 275/60 R15 as others have done I just don't like the "look" of the back tire hope it will "look" right with the change....yes my wife says it a lot "NEVER SATISFIED!!!" I don't have a glue what she is talking about!!!! What do you all think? To low? Just right? Well I will update with more pictures as I do more work to it. Thanks Robert
GMC"ER is offline   Reply With Quote
Old 11-30-2011, 11:20 PM   #2
geezer#99
geezer#99's Avatar
Re: Still working on the 69 GMC stepper! Just not satisfied with my tire size?????
Changing to a 275 on the back won't change the look much. 275 is about 1/2 inch shorter and an inch wider. Your 215's on the front look to small. JMHO.
Old 11-30-2011, 11:51 PM   #3
mikey531
mikey531's Avatar
I agree the front tires look small
mikey531 is offline   Reply With Quote
Old 12-01-2011, 02:37 AM   #4
russellmarling
russellmarling's Avatar
great looking truck! The stance is almost perfect. As far as the tire sizes go, I run a 245/60/15 on my 15x7s on the front, and a 255/60/15 on 15x8s on the back, and I like the look. Mine are also on a dropped GMC stepper. What color blue is your truck? I'm getting ready to paint mine and still trying to decide which shade of blue I want.
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress)
'09 CTS-V M6
'03 Sierra SWB Z71
'82 Yamaha Seca XJ650R Turbo!
'04 Yamaha FZ6
russellmarling is offline   Reply With Quote
Old 12-01-2011, 07:18 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
I think it looks great.
275/60's on the back will be fine.
I know alot of people think those front tires look too small,... but you have to be able to drive it.
With the inner fenders installed,... the tires are real close to hitting them.
(plus the a-arms are 2.5" off the ground)
Ask me how I know,...
Keith
Convert to disc brakes.
Old 12-01-2011, 09:49 PM   #6
GMC"ER
Thanks for the input guys! I know that if am not satisfied on the first look of something I might as well change it as it will drive me crazy until I do! Well I am going to change the back to the 275/60 R15 or some other size??? The back tires look like "balloon" tires to me against the front tire size so I will see how it looks with another tire size it is only money! I have spent to much to worry about it now! And Keith is right about the front tire size it is the biggest size I can get under the front and still drive it without scrubbing the front tires. Thanks for the input and as always I like to see more truck pictures with the same or similar setup. Thanks Robert
Old 12-01-2011, 09:52 PM   #7
GMC"ER
As far as the paint color I have it wrote down out in the shop but I will have to get the color name for you tomorrow and post it for you. Robert
Old 12-01-2011, 10:04 PM   #8
CC69Rat
CC69Rat's Avatar
I'd leave it ! Just my.02.
Chad
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-01-2011, 10:09 PM   #9
bajaracing
bajaracing's Avatar
truck looks good as is. Nice & clean!
bajaracing is offline   Reply With Quote
Old 12-01-2011, 10:38 PM   #10
Autoblueprint
Autoblueprint's Avatar
Lightbulb Re: 69 GMC stepper...just not satisfied with my tire size.
Your Stepper does not look bad with what you have on it, but tire / wheel combos are a matter of individual taste, so go with your gut, when it's right you will know it.
I find this a usefull tool in the tire / wheel selection process, check it out.
Wheel / Tire Size Comparer:
http://www.rimsntires.com/specs.jsp
Here is what I ended up doing with mine.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 12-01-2011, 10:47 PM   #11
502ms
502ms's Avatar
I'm going to be figuring this out....my 72 stepper is being set for laying frame. I wanted to run 8" rally's all the way around...
Those 7" could come in handy.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 12-02-2011, 01:33 AM   #12
crazy longhorn
Fabricate till you "puke"
I run a 255/70/15 rear, on a 8" wide ralley wheel(rear)....fronts are a 225/75/15, on a 6 1/2" van ralley. Its a nice combo, & the fronts clear easy. My old truck does not run inners(steel tilt clip). My thinkin says, you are about right on the height on the rears....but not wide enough(go 255/70). Up front, you need to step up on the tire(225/70 or 225/75 should work), but you may have to tuck em in a tad(6 1/2" rim). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-02-2011, 05:05 PM   #13
Ilike 72"s
Here's one I built and sold. I adjusted until I got the tires the same level as the fender lips. Some said the tires were to big, but thats the look I was going for.
Ilike 72"s is offline   Reply With Quote
Old 12-02-2011, 07:37 PM   #14
windmill
windmill's Avatar
well the guy post pics of truck and talk's about looks ,,,,, what about some size of the tires and wheels....
72 swb pickup
http://i124.photobucket.com/albums/p...k/100_0958.jpg
1967 chevelle ss
1966 mustang getting a l33 ls motor
1969 chevy dump truck
1989 mustang 6.0 ls best time of 1.29 at 5.91
https://www.youtube.com/watch?v=JtbooZoGZmQ
windmill is offline   Reply With Quote
