06-17-2012, 04:14 PM | #126 |
Re: Impala SS Rear Disc Brake Brackets
hey do you still have some...if so ill need your pay pal info
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604) |
06-17-2012, 11:52 PM | #127 |
60-66 Nut
Hello. Yes I do still have these. My parts are not limited in quantities. I'll send you a PM with my PayPal info.
01-09-2013, 02:44 AM | #128 |
Interested in a set if still available.
Thanks Chad Posted via Mobile Device |
01-09-2013, 09:18 PM | #129 |
Can you send me directions for payment on the impala brackets for 1968 gm 12 bolt. Do you know if I can get inspection without an emergency brake, I'm in Texas?
Stephentyler0611@gmail.com Posted via Mobile Device |
01-09-2013, 11:22 PM | #130 | ||
60-66 Nut
A PM is coming your way with payment details.
I have no idea if Texas requires an e-brake or not. If you have to get a vehicle inspection, more than likely you will have to have an e-brake. Quote:
03-17-2013, 09:26 PM | #131 |
Hey , I think these would be a better fit since I can get different rotors so please pm me with payment info and ill PayPal it ASAP
Thanks mike Posted via Mobile Device
///Relaxed Atmosphere |
03-17-2013, 11:21 PM | #132 |
60-66 Nut
I'll send you a PM......
03-18-2013, 11:03 AM | #133 |
Project collector
Can anyone tell me how they plumbed these brakes for the rear? Do I have to use the rubber brake hose with the banjo bolt or can I add an adapter of some sort and plumb the hardline directly into the caliper?
Thanks, Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! |
03-18-2013, 10:56 PM | #134 |
60-66 Nut
Some of the older rear disc calipers were plumbed directly with a hard line. I prefer to use a rubber or braided stainless hose from the caliper to the hard line on the axle tube. You can use the one for the Impala with a Metric to SAE adapter.
03-19-2013, 03:40 PM | #135 |
Texas requires a FUNCTIONAL E-brake on all vehicles so equipped.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-23-2013, 01:44 PM | #136 |
parts are great !!! mounted up no issues at all (: ,
hub size on the impala rotor needs to be opened up to 79.5 mm great product!!!! thanks
03-23-2013, 11:01 PM | #137 |
60-66 Nut
Thanks for the compliment
That's strange that you had to open up the center hole of the rotors. I did not have to do that with mine. The typical hub register on a 5 x 5" axle flange is 3.06" or 77.7 mm.
03-24-2013, 07:36 AM | #138 |
ok, cool my axles had a step on them that was 79.45 so i just opened them up just oh so much ,maybe just my set ? still outstanding brackets
the pads were tight too but i machined the rotors down 003 and its fine Posted via Mobile Device
03-29-2013, 03:08 PM | #139 |
Active Member
I'd like a set of these as well, can you PM me Payment info?
For anyone needing calipers Fedex just dropped off a pair of remanufactured Kelsey Hayes loaded Impala SS rear calipers, they came with pads and the brackets. They were on closeout for $50 shipped for the pair ($20.08/ea + $10 shipping) on Rockauto. Since they're on closeout to go along with the cheap price there is no core charge. It doesn't say how many they have left. Being able to get the calipers that cheap I think I should be able to get the swap done with zinc coated slotted rotors for around $250. |
03-30-2013, 12:32 AM | #140 | |
60-66 Nut
PM coming your way......
Thanks for the info on the calipers Quote:
04-28-2013, 06:15 PM | #141 |
Hey just checking for 88-98 yet
04-28-2013, 11:48 PM | #142 |
60-66 Nut
Sorry, no time to work on those. I'll be working 80-100 hrs a week the next two weeks.
05-03-2013, 02:03 AM | #143 |
hey captain
could u email the parts list ? i lost it and now i need the line and bolt info since i bought the wrongs one blazins10@msn.com Posted via Mobile Device
05-05-2013, 12:09 AM | #144 | |
60-66 Nut
Sorry for the delay, things have been crazy for me this last week. I will get that list emailed to you in a few minutes.
05-05-2013, 01:39 AM | #145 |
i had a hard time finding the dorman banjo bolts
but found them in the help section part # 13912 Posted via Mobile Device
05-07-2013, 05:46 PM | #146 |
Captain Fab! I sent over a PayPal today for the 12 bolt bracket kit.
Thanks Dan Posted via Mobile Device |
05-07-2013, 11:27 PM | #147 |
60-66 Nut
Your payment has been received. I will try and get those shipped out on Friday. If not it will be Monday.....I am seriously backed up right now.
05-21-2013, 11:05 PM | #148 |
Thanks for the great brackets Captain! Quick question..looks like the brackets mount 2 different ways. Should they mount on the bottom of the axle or the top? I think I've seen pics of Impalas calipers mounted on the bottom but I'm unsure.
Thanks for your help. |
05-22-2013, 02:22 AM | #149 |
60-66 Nut
When I re-designed these brackets I did so with the idea of the caliper mounting in aprox the 2 O'clock position. However you can mount them however you like. Just be sure the bleeders are on top.
06-04-2013, 12:19 PM | #150 |
hey Capt. I would like a set as well. pm me with info.
