Old 12-26-2012, 10:27 AM   #176
msaintg
msaintg's Avatar
Re: 1947 S10 4x4 Blazer swap
I think it would be a lot more work at this point to, A - lower the front of the fenders, B - raise the front of the cab, or C - trying to shift everything around. So, that is why I decided to trim the hood. Everything sits good now (when the hinges are not attached), I just have to figure out how to modify the hinges. I have a new set of hinges coming in the mail on Friday, if I screw these up.
msaintg is offline   Reply With Quote
Old 12-26-2012, 11:41 AM   #177
87Jimmy4JP
let us know how you make out....
I know what you mean about finding the best overall solution....
JP
87Jimmy4JP is offline   Reply With Quote
Old 12-26-2012, 12:33 PM   #178
jed971959
truck is looking good
I have not tryed this but did some reading on the ext oil filter
the adaper that the ext oil filter screws on to can be unscrewed
and just screw it into the engine block so the filter goes on the engine
without buying anything
just thought I would share this with you
I read blazer have problems with the oil lines leaking
I've had 4 blazers and no problems with oil leaks but just in case
maybe try this when I move my engine back
jim
jed971959 is offline   Reply With Quote
Old 12-30-2012, 07:19 PM   #179
msaintg
msaintg's Avatar
week 46 - I have been lazy this week... only did a little work on the tailgate to close in the ends. I also spent waaaaay to much time trying to get a title for my project truck. The 47 did not have a title or VIN plate, so a bonded title would be necessary IF it was still stock. The Blazer only had a 'non-repairable' title (AZ MVD translation.... "you can't use ANY parts from this vehicle to build your 1947") What? Holy crap! You mean, "I have to replace the frame that I spent so much time on?" Plan B, buy a cab with a title. I found a 1960 cab. Not as old as I would have liked, but who really cares what is on the title as long as I can register it without having to emission it.
Old 12-31-2012, 11:01 PM   #180
Root2812
Root2812's Avatar
I'd be careful with that. If you ever get pulled over and have a title and registration that says 1960 and your truck is clearly not a 1960 you could get your truck confiscated or atleast impounded. It is illegal to switch a vin/id tag from one cab to another. You can get away with it if they are like years because no one can tell. ie and AD tag to another AD cab. You may want to keep looking. Atleast thats how it is here in Minnesota and most other places I am familiar with. I know this because my father and I asked a state trooper with the vehicle inspection team (custom cars and repairables get inspected) about it since my dad is building a custom wrecker for his buisness.
Good luck and good work.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 01-01-2013, 05:31 AM   #181
msaintg
msaintg's Avatar
I know exactly what you mean, but I am screwed either way if I get stopped and they start checking.... I was sold the Blazer as repairable or for parts use. The DMV guy said 'No', I can't use any parts off of the Blazer because of how the insurance company closed out the title. Since 90% of the truck is actually a 1996 Blazer, I could never get it through inspection. That is the only reason I went this route... it is really my only choice. I found a guy on CL selling a 1949 cab for $700 (with title), but when I got there, he decided he didn't want to sell it.... but suddently had just a title and VIN plate for 'another' cab that he wanted $500 for. What an A$$ hat! Needless to say, I left empty handed. That guy is still posting that same cab on CL too. I flag him every chance I get. It sucks when you are trying to do the right thing and the 'system' screws you for it. I am not worried about getting pulled over and inspected anyway. This is only a weekend cruisor I am building.
Old 01-01-2013, 10:30 AM   #182
daverod
SSN 706
daverod's Avatar
That sucks. People get all excited about building a truck and they forget about the most important thing. Hope it works out. I've heared stories of people losing there projects because they used a hot s10 frame.
daverod is offline   Reply With Quote
Old 01-01-2013, 12:35 PM   #183
gregw98
gregw98's Avatar
Give Broadway titles a look-see. http://www.broadwaytitle.com/
Check with this guy. http://cosprings.craigslist.org/pts/3449871862.html
gregw98 is offline   Reply With Quote
Old 01-16-2013, 04:10 PM   #184
msaintg
msaintg's Avatar
week 48 - Sorry guys, nothing much to report. Since I work nights, I have not been able to work on the project truck because it has been too cold to paint anything. All I have managed to get done is get the hidden latches installed on the tailgate. I picked up some insulation for the cab and finally got a title. Oh well, maybe next week. mike
Old 01-16-2013, 07:32 PM   #185
rgunlock
rgunlock's Avatar
Getting the title has to be a big relief. What was your solution for this?
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is online now   Reply With Quote
Old 01-21-2013, 06:46 AM   #186
msaintg
msaintg's Avatar
week 49 - Wow, way back in week 45 I spray painted some red primer on a fender and the tailgate. I have been trying to finish the sanding on these two pieces ever since. I thought it was the cold, but now I think I might have just got some bad primer..... it NEVER dried. I can't believe how much sand paper and time I have wasted trying to finish these parts. I ended up stripping all of the red primer off this week and redoing it with a gray primer. I didn't get all of the red primer off at first, so the gray primer cracked when it was over the red primer. Here are a few pics of the cracks. Go figure, huh. Well, hopefully I will have these two parts painted by the end of this week. Mike
Old 01-22-2013, 06:06 PM   #187
msaintg
msaintg's Avatar
Week 49 - I worked through the primer problems and got paint on the tailgate and drivers side fender. Next I have to get the gas filler tube attached.
Old 01-22-2013, 06:43 PM   #188
87Jimmy4JP
nice work on the tailgate and fender...look great...
good luck with that title thing, too!
JP
Old 01-24-2013, 07:56 AM   #189
dirt53
dirt53 is offline   Reply With Quote
Old 01-25-2013, 04:55 AM   #190
msaintg
msaintg's Avatar
Thanks, I was hoping to have the body work done before I hit my one year anniversary, but it doesn't look like I will. Hopefully I will be able to get the running boards and last fender done by next week. I have been putting off the doors till last because they need a lot of work and I am afraid they are not going to fit correctly and I can't decide what kind of latches and door handles I want to use with them.
Mike
Old 01-25-2013, 08:04 AM   #191
87Jimmy4JP
Mike
I understand about the timeline thing...anniversaries are important, ect....though these things take on a life of their own and you have put details elsewhere that I bet you didnt quite plan for at the beginning.
I just took a look at the whole post and realize how neat this project is...didnt think that a 50's truck could so successfully be put on a blazer frame like this.
cool
JP
Old 01-28-2013, 10:47 AM   #192
msaintg
msaintg's Avatar
wow, what a weird January we are having here in AZ... record cold, record heat, and now record rain! WTF?
Old 01-29-2013, 01:33 AM   #193
gregw98
gregw98's Avatar
Same going on here in New Orleans. 11:30 at night and 68 degrees. Not complaining, but weird, it's still January.
Old 01-29-2013, 08:27 AM   #194
87Jimmy4JP
I really like the above picture for some reason....the truck has a "snoopy" "Joe Cool" like personality...cool shot!
JP
Old 01-29-2013, 02:38 PM   #195
msaintg
msaintg's Avatar
Snoopy, thats funny. Just looks very lonely to me.
Well, week 50 did not show much progress. I worked on the last fender and running boards, got most of the rough body work done. Put some body filler on everything and called it good enough. All I have for pictures is a before shot of the fender. It will give you an idea of how messed up it was to start with (it was actually one of the best ones as far as holes and dents go). The running boards were trashed. I pounded them out the best I could, but I just could not get them straight. I will just have to live with them that way.
Mike
Old 01-29-2013, 02:45 PM   #196
Daze57
Daze57's Avatar
great job on poundin them out !
i am sure on this site you might be able to find a fender or two in better shape if ya wanna go that route - other than that truck looks great !
Daze57 is offline   Reply With Quote
Old 01-30-2013, 05:09 AM   #197
msaintg
msaintg's Avatar
thanks, it is quite the stress reliever to beat on old metal. Since I only paid $500 for the whole truck, it is hard for me to justify spending hundreds of dollars on other used parts.... bondo is cheap. People here in AZ are VERY proud of their crap too. Sellers ask thousands for stuff here that would sell for a few bucks other places (and then they wonder why it does not sell). I don't get it. I figure I can't make my crap any worse by trying to repair it, so if I can salvage it, I am ahead. If I replace every part on this truck that was worn out, there would be nothing left to call the original truck. mike
Old 02-06-2013, 03:35 AM   #198
msaintg
msaintg's Avatar
week 51 - I finally got the last fender and the running boards painted. Nothing bolted on yet. I also decided to take a one inch wedge cut out of the hood..... partly because I got too frustrated trying to line the thing up and not being able to see what was going on under there.... but mostly because I like the look. I will probably spend the next couple of weeks getting fenders and running boards mounted and get the hood to fit.
Mike
Old 02-06-2013, 05:02 PM   #199
msaintg
msaintg's Avatar
I forgot, I also got the gas filler tube and door attached.
Old 02-06-2013, 05:55 PM   #200
gregw98
gregw98's Avatar
That is looking so good. If my garage was ever that clean, it would be a miracle.
