10-16-2013, 05:36 PM | #26 |
70+ ( Old Skool Club )
Re: Ground strap locations
Board member/vendor VH Coachworks sells a professional quality ground strap kit that is second to none and its not very expensive. There is also instructions on where to place the ground straps. I have one of those kits and wil be installing it very soon.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-11-2014, 02:41 AM | #27 |
Can anyone with a step side tell me where the oem ground strap goes on the bed? I already landed one end on the frame using the location shown at the first of this thread. I suppose the other end goes to a crossmember (i have a step side with wood bed and the floor and cross members are not yet installed)
08-28-2014, 02:49 PM | #28 |
The Older Generation
I am going to bump this back to the top and add a picture of the instrument cluster ground clip location. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-21-2018 at 11:51 AM. |
11-26-2015, 06:47 PM | #29 | |
Like this:
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
11-26-2015, 06:50 PM | #30 |
I bought 2 kits because I had done a lot of powdercoating and wanted to be doubly sure about grounds.
For cosmetic restoration purposes, I used laquer thinner and a bead blaster to "restore" my copper originals. I wonder if the Corvette shops sell the original copper style still? No aluminum strap is going to impress an NCRS judge...
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
11-26-2015, 07:20 PM | #31 |
[QUOTE=davepl;7390010]I bought 2 kits because I had done a lot of powdercoating and wanted to be doubly sure about grounds.
For cosmetic restoration purposes, I used laquer thinner and a bead blaster to "restore" my orignals. I did the same cleans them up nice. I also grabbed a few of various sizes from the jy. After cleaning then all I clear coated the strands in hoping they keep there color. Guys don't forget the proper ground washers are important. Lock doc good call on that ground most forget it. Mine clips too the choke cable. Also the ground on the heater blower motor.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
11-26-2015, 08:59 PM | #32 |
There's no need to run grounds larger than the low current feed from the battery and alternator. The big cables bolted to the battery carry the large starter current.
11-26-2015, 09:29 PM | #33 |
Proper grounding through out the body to frame to engine redirects static electricity discharge so it doesn't destroy wheel bearings. Discharge straps to earth ground in the wrong place can kill wheel bearings as well.
04-12-2016, 07:42 AM | #34 |
Any other thoughts on grounding a stepside bed?
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
04-12-2016, 09:42 AM | #35 |
One of the perimeter bed bolts, header panel bolts, or rear cross sill bolts should work fine unless there is rust between all of the panels.
LockDoc
04-12-2016, 10:35 AM | #36 |
All fresh painted panels. With clean bolt holes. But no metal to metal between the panels. Thinking of a ground strap between the rear cross member and the frame. Then maybe adding wires between the taillight brackets and the frame
04-12-2016, 03:14 PM | #37 |
On my fleetside, is it recommended to ground to one of the box cross sills? I didn't really think about that too much when I applied all the POR-15 to them. Might make for an interesting scrape job to get to bare metal on one.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
04-12-2016, 05:27 PM | #38 |
as if too manny isnt enough, you should also ground the distributor to the intake manifold and to the fire wall. if you have aluminum heads, ground them to the intake as well and to the block. Dont rely on head bolts to do it.
this is important enough but if you have a large electronic load, its even more important. Oh and just for the record.... bonding straps complete the circuit, ground straps discharge static electricity. |
04-12-2016, 06:18 PM | #39 | |
I am not saying that it is not a good idea to do so. |
04-12-2016, 06:33 PM | #40 |
I checked my circuits and found out I had a bad bulb. Replaced them all and did some checking and just ground the rear bed brace to the frame and we are off and running.
04-12-2016, 08:55 PM | #41 |
Why use a braided strap vs a wire? I installed a wire tonight for a test and it worked. I was going to swap it out for a braided strap but I ask why? This is between the rear bed cross member and the frame for the tail lights
04-12-2016, 11:56 PM | #42 |
Braided wire is more flexible and your box is mounted on thin rubber washers. You need to ground the box, I would do both sides of the box.
04-13-2016, 12:26 AM | #43 |
Good information here. Thank you.........Turns out mine was missing the strap for the bed rail. Correct me if I'm wrong, but the hole for this in the frame is approx. 13" from the end of the frame.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-13-2016 at 12:52 AM. |
04-13-2016, 05:36 AM | #44 |
If flexible is the only reason then I am going to stick with the wire. Why change it?
04-13-2016, 06:14 AM | #45 |
Were all of the boxes mounted on rubber washes? Can this be confirmed by anyone? I've seen the pads in maybe one online source. I didn't put them under my bed, maybe I should have.
04-13-2016, 07:31 AM | #46 |
I have them installed on my stepside. I think I got them from Classic Parts of America
04-13-2016, 10:43 AM | #47 |
Working for a phone company definitely has its perks. They have a multitude of different grounding materials. I'm going to upgrade my grounds to this half inch strap. I can cut to necessary lengths.
04-13-2016, 12:35 PM | #48 |
Great Idea! I am going to pay more attention to grounding before I go chasing anymore of the gremlins that live im my electrical system.
Blue 1972 Chevrolet C-10 Camper Special 350ci/Muncie M-20 4-speed |
04-13-2016, 12:58 PM | #49 | |
For example, newer vehicles don't rely on a tail light's housing to provide a ground. A ground wire comes out of the housing and is grounded at another location. If GM had done that back in the 60's we probably wouldn't be having this discussion now.
04-13-2016, 01:00 PM | #50 |
Moderator
Exactly.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
