09-23-2014, 10:06 PM | #1 |
'48 awakened from long slumber
Hi everyone, I haven't had much time in a long time to work on my '48 chevy due to my job. As of this past Sunday, the engine is running! Hasn't ran in 35+ years. I spent all Saturday and Sunday working on getting engine ready for firing engine. 60 psi oil pressure at idle, engine doesn't smoke, purrs like a cat lol.
Here's my question, I noticed there was a puddle of water underneath. There was a tan color under the flywheel. It appears to been coming from the input shaft of the 4 speed, inside the bell housing. Has anyone heard of this, or had a similar incident? The engine is a I believe a 283, not sure. Has a weird pvc valve where road draft tube is on back of engine. Has stock inclosed driveline 4 speed trans backed behind it. Gotta rebuild 2 barrel, and order brake parts for this weekends visit. Many thanks, Dave |
09-23-2014, 10:12 PM | #2 |
Re: '48 awakened from long slumber
...and post photos!
Sounds like you are back on the project, though.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
09-24-2014, 12:04 AM | #3 | |
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
09-24-2014, 10:57 AM | #4 |
Hi guys, thanks. I'll try to get photos up. Not sure what the heads are, will pull valve cover to get number, there is a triangle on the front of heads. No bolt holes for accessories. Engine is pretty close to firewall to read rear left side on block. I wrote down the numbers from front passenger side pad, F0I27GF.
09-24-2014, 01:44 PM | #5 |
Might have one of these freeze plugs leaking. First attempts at PVC systems replaced the draft tube with a fitting and hose to bottom of carb.
09-24-2014, 03:44 PM | #6 |
All about them K’s
+1. If you've got water coming from back there it can really only be the freeze plugs or the intake leaking. When I put the 350 in my '57, upon filling the radiator I had a massive leak back there and it turned out to be a busted freeze plug.... Talk about aggravated, had to pull the trans back out to put a new one in.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
10-02-2014, 01:38 AM | #7 |
Hi guys, back of the block was dry, just the input shaft side of trans was wet. I did manage to get the brake system rebuilt/replaced last weekend. Doing electrical, and hopefully exhaust this weekend. Will have to look into the mystery leak more while under there . I cannot figure out how to post pics from my phone, is there a forum or something on Facebook you guys go to?
Dave |
