Old 04-20-2015, 06:39 PM   #51
72 tigger
72 tigger's Avatar
Re: A different approach to a LWB to SWB conversion
You obviously know what you're doing- (nice job on the COE too!). All the welding drama is entertaining, but I'm excited to see how you do the rear also. Thanks for sharing with us!
72 tigger is offline   Reply With Quote
Old 04-20-2015, 06:57 PM   #52
CarterD2015
CarterD2015's Avatar
I think that the thread title says it all. "A DIFFERENT approach...." Different is just that, different. No claims of being better or worse. It is enlightening to see another person's approach to a common task. I look forward to the rest of the build.
CarterD2015 is offline   Reply With Quote
Old 04-20-2015, 07:10 PM   #53
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: A different approach to a LWB to SWB conversion
36 years in the nuclear construction area and as a fitter I have seen every type of weld there is and by all means this guy knows what he is talking about. I'm glad to see him doing it this way. There is more than one way to skin a cat as they say!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-20-2015, 10:28 PM   #54
bollybib
bollybib's Avatar
From my point of view, the phrase "Ignorance is bliss" comes to mind. Cuz I'm really liking this guys work and I don't know all that much about the practical aspects of welding and metal work.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 04-20-2015, 11:10 PM   #55
no1udknow
no1udknow's Avatar
I shortened my frame the other way, by cutting the long straight section under the cab. The reason most guys do it there is so they dont have to risk messing with the trailing arm geometry. when you cut it behind the cab you either have to move the trailing arm x-member forward, or shorten the trailing arms (horrible idea). the reason a pen weld is not suggested for these frames is that the metal is fairly soft, and the weld is very hard which makes it rigid and is prone to cracking. Most frames will either do a diagonal cut or an s cut like mine. if you have a vertical pen weld, I would definitely box the frame to spread the stress away from the weld . Having done mine now, i wish I would have taken your approach on the bed. lining up and welding the entire bed section was a pain.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 04-21-2015, 11:13 AM   #56
cooperhw
cooperhw's Avatar
I have shortened more than a couple of these frames but am no way anywhere close to any of these professional welders.
Will this frame fail, more than likely not. Looks fine to me.
Would I plate it anyway, H*ll yes. Why not. If you don't want it to be seen fish plate the inside.
Really though, most of these trucks lead somewhat of a pampered life once they end up in our hands. We use our Diesels for heavy hauling.
OP, carry on sir, you are doing a fine job.
Those pointing out potential weakness in the frame butt weld I agree. For most guys (me included) this method should not be used. Leave it alone (or to the professionals) and use a step notch. I even plate these. Cheap & easy insurance for me.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 04-21-2015, 11:45 AM   #57
65standard
65standard's Avatar
As I said 95% will not like my welded frame. Stay tuned for the rest of the process. I think 95% will like my bed shortening technique since I eliminate over 20' of weld.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 04-21-2015, 11:55 AM   #58
lolife99
67-72 parts collector,…
lolife99's Avatar
Looking forward to the bed work!
Keith
Convert to disc brakes.
Old 04-21-2015, 12:03 PM   #59
67ChevyRedneck
67ChevyRedneck's Avatar
I keep checking in and it's more bickering, I keep hoping for new pics!
(and now someone else will check in hoping to see progress and see my post, and be like... a-hole...)
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-21-2015, 12:22 PM   #60
jjzepplin
jjzepplin's Avatar
Me too. I have been a lot of places and seen a lot of things. BLAH BLAH... but your work here is very nice and don't let it discourage you in any way this talk about the frame. If it cracks then you can plate it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-21-2015, 08:42 PM   #61
Dads79GMC
Dads79GMC's Avatar
I don't drop by the 67-72 forum very often, but I'm glad i did, this is great work!!!! I like seeing another approach. Anxious to see how you tackle the rest of the box side? Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 04-21-2015, 09:23 PM   #62
shawno72
C/10 junkie
shawno72's Avatar
Me too. Let the bed work commense
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 04-21-2015, 11:19 PM   #63
BigMike
BigMike's Avatar
I love outside the box thinking. You don't see it much because of the many builders before us thinking outside the box. Many of those older ideas have become the norm. Who knows, maybe in another 10-20 years 65standard's way will be the norm? Can't wait to see more.
BigMike is offline   Reply With Quote
Old 04-21-2015, 11:46 PM   #64
simplepeddler
mad skills for sure
simplepeddler is offline   Reply With Quote
Old 04-22-2015, 12:54 AM   #65
swamp rat
swamp rat's Avatar
Thanks for comming back!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-22-2015, 01:35 AM   #66
orngsikL
orngsikL's Avatar
Man!!! That is nice. I always thought there was a better way to do this. Very nice work!
I would still add fish plates, that's just me.
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
Old 04-22-2015, 10:40 AM   #67
ls1nova71
ls1nova71's Avatar
I'm in for how he does the rear of the bed, but I'm thinking this is where the original paint is going to get burned a bit...
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-22-2015, 02:49 PM   #68
no1udknow
no1udknow's Avatar
I already like the way you did the front of the box, that is genius. I wish I had seen it before trying to cut and weld mine.... would have saved me a lot of grinding and bondo
Built not bought!
Old 04-22-2015, 04:02 PM   #69
dubds10
Stalker Nate
Nice work and actually done by a certified welder not a backyard hack with no tickets lol Lots of pro welders/fabricators here who know what they're doing and it's great to see the work when completed and actually know the vehicle is safe. Unfortunately I bet only 25% of the trucks on the road today that are being built are done by certified welder/fabricators who really know what the hell they are doing. It's scary looking at airbagged or chopped up trucks at car shows and thinking they actually drive that on the highway when you can visibly see how bad the welds are or the alignment of everything.
This is actually a great method of doing it if you want to hide the fact it's a chopped down LWB from unsuspecting buyers, but I doubt many of the guys chopping LWBs could even pull something like this off anyways lol Can't wait to see how the bed turns out overall.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 04-22-2015, 05:44 PM   #70
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Fine work! Am I mistaken that this is the truck you pulled out of a salvage yard a short time ago? It is great to see high quality skills put to use in a personal setting for your own purpose and needs.
Please continue on with your build and post pictures please!
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 04-23-2015, 10:05 PM   #71
LongNLowGMC
LongNLowGMC's Avatar
Everybody harping about the frame, meanwhile completely missing the fact he's shortening the bed while keeping all the original paint. Coolest way I've seen this done thus far, can't wait to see the end result. Keep up the good work man!
-Vince-
67 SWB Small Window
70 CST SWB - Long Gone
72 GMC 1500 LWB - Sold
LongNLowGMC is offline   Reply With Quote
Old 04-23-2015, 10:40 PM   #72
72_K10_Vegas
72_K10_Vegas's Avatar
What Andy said.
72 K10
72_K10_Vegas is offline   Reply With Quote
Old 04-23-2015, 11:45 PM   #73
NTIMID8R
NTIMID8R's Avatar
Very nice work Tony...
For all the haters: read the last sentence in Tony's post #26.
PLEASE keep posting pics!!!, want to see this to the end...
Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present".
1971 Sierra Grande LWB, 350/TH350, Factory Air Lots, of future mods planned!!
NTIMID8R is offline   Reply With Quote
Old 04-24-2015, 04:14 AM   #74
mechanicalman
I'm planning something similar, but planning on removing the rear cab mounts then do a short "Z" like you did but going to the underside of the frame towards the cab, going between the top and bottom row of rivets that hold the rear cab bracket on so that the bracket can be reinstalled into those two holes (still located as before) and then simply drill those two lower holes right through the bracket and add the two other bolts.
Still, your's will be more than strong enough. People over-look the fact that when you cut BEHIND the rear suspension cross-member on coil spring trucks that most of the stress is actually AHEAD of the rear suspension cross-member. Accelerating, braking, all goes into the cross-member. Only time the rear section of frame behind the suspension cross-member sees much stress is when you are towing. Think of it as a tow-bar LOL.
Ignore the static, you are very good at what you do.
mechanicalman is offline   Reply With Quote
Old 04-24-2015, 05:32 AM   #75
bpatrol
I would say to go forward and progress you have to see different ideas. No one has seen this before as far as I can tell. He has done a wonderful job. Imagine how many would love to shorten their longbed but don't because of the originality of the paint. He just showed you a way with out excess heat,warping or body filler. I am excited and completely clueless how he will do the rear.
He has exceptional talent and the one thing many don't have, IMAGINATION and the nerve to do it and post it for all to see.
Im no welder but this is a guy I would love to learn from.
so 65standard, or Tony if that is your name, I am impressed and realize we don't know everything
bpatrol
bpatrol
bpatrol is offline   Reply With Quote
