05-21-2015, 11:22 AM | #1 |
Moderator
Tach wiring help?
05-21-2015, 11:57 AM | #2 |
Re: Tach wiring help?
Pink wire to ignition
Gray wire to dash lights Brown wire to neg - side of coil Pink wire to pos + side of gauge. Brown wire to - side of gauge. In your case it looks like you have a black wire for the light and not grey which would have been factory color. Also.....HEI or coil?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
05-21-2015, 12:00 PM | #3 |
Also....great thread here....go to tech articles.....install tach 64-66
http://www.earlyclassic.com/tech.aspx?category=Install Tach 64-66 Chevy3
05-21-2015, 12:02 PM | #4 |
Check The Champ, Demonstrator
The black top wire is for a light is it not?
Red terminal to the + of the coil. It looks like you would not need a sender unit. Do you have a Chevy or GMC? On Chevrolet it went through a grommet along with the windshield washer hoses? Did I remember correctly?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
05-21-2015, 01:42 PM | #5 |
Moderator
I have a Chevy 230. Original points.
That black wire at top is coming out of the light housing, for sure. |
05-21-2015, 02:14 PM | #6 |
Senior Enthusiast
The following link is the closest I can find to your exact tachometer:
http://www.classicglastron.com/phpbb...pic.php?t=7376 Also, blowing the photo up 400% and sharpening the image a bit, it appears there are very faint + and - marks indicating the post orientations in the original 2nd photo: It also appears this unit was manufactured by AC Delco. There are a few pictures of them on Google Images.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 05-21-2015 at 02:26 PM. |
05-21-2015, 02:41 PM | #7 |
Moderator
Thanks. Great detective work! For 20 bucks, I think I'll give it a shot.
05-21-2015, 03:01 PM | #8 |
Senior Enthusiast
Correction - I found another similar tach on Images, and it clearly shows the upper center stud being the 12v connection (as does yours). This means one of the lower studs is for ground, and the other is for the signal wire, not 12 volts positive. Unfortunately I can't detect any markings on this other tach even under extreme magnification, so I would suggest doing low voltage testing of the gauge to determine which is the correct post before "going live":
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
05-21-2015, 06:28 PM | #9 |
i agree with Markeb ^^^^^^^^^^^^
05-21-2015, 06:49 PM | #10 |
Have you taken the mounting bracket off to see if theres any id there?
I definitely agree the red post should be the pos
05-21-2015, 07:29 PM | #11 |
Moderator
Maybe... 12V+ on the red post (and the light lead), coil+ on the + post, ground on the - post... just thinking out loud.
