Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-03-2018, 05:17 PM   #1
TXLSX
67-72 Kick Panel speakers
I recently bought some kick panels with speakers from classiccarstereos.com and I thought I'd share some photos. If I could do it all over, I would have just bought the panels without speakers and bought the speakers separately. The grilles that came with the infinity speakers are bulky and ugly so I went with a universal low profile grille from amazon. When I test fit them, they fit well and didn't require the dimmer switch to be moved. I'll add more pics once the install is complete.
TXLSX is offline   Reply With Quote
Old 04-12-2018, 04:18 PM   #2
demian5
demian5's Avatar
Re: 67-72 Kick Panel speakers
I just used double sided 3m trim tape to tape mine to the truck after putting fat mat on the kick panel of the cab. Worked great, its a snug fit that holds them in already so the tape is really just an added insurance they don't fall out when cranking up the volume.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-15-2018, 02:08 PM   #3
TXLSX
The panels ended up fitting pretty well. Had to chop a little piece off the pass side to clear a bulge in the firewall that goes to the fresh air vent but that was about it.
Old 04-17-2018, 02:05 PM   #4
Hart_Rod
Hart_Rod's Avatar
Those look really good! I had to make the same adjustment on the ones I got from RetroSound.
Hart_Rod is offline   Reply With Quote
Old 02-21-2019, 08:35 PM   #5
elorenzof
Hart Rod do you notice a difference with the tweeters in the kick panels vs not having them?
elorenzof is offline   Reply With Quote
Old 02-22-2019, 08:02 PM   #6
michael bustamante
michael bustamante's Avatar
I had to trim mine as well. good fit now. went with bostons for speakers.
1967custom
michael bustamante is online now   Reply With Quote
Old 02-22-2019, 08:17 PM   #7
rsavage
rsavage's Avatar
Parking brake?
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-22-2019, 12:09 PM   #8
Flubyu
I too am curious about components vs. coax. Also in for info on the lack of a e-brake!
'71 C-10 SWB Shop Truck
Currently 350/350, soon to be LS'd.
Flubyu is offline   Reply With Quote
Old 10-23-2019, 03:54 AM   #9
cmcolumbus
cmcolumbus's Avatar
I'm in process of installing mine but the parking brake is in the way, I'm thinking of removing it and reposition it or bend it to clear the speaker
cmcolumbus is offline   Reply With Quote
Old 10-23-2019, 01:16 PM   #10
SunSoaked
SunSoaked's Avatar
I couldn't live with the cheesy, plastic aftermarket kickpanels so I made my own. All you need is some MDF, fleece, fiberglass resin and some imagination. The result is a much better, more durable kick panel that allows you to use quality speakers.
I'm using a "Focal" 3 way component system and subwoofer. This is my 85 but the process is the same. You can buy metal grills online and whatever else your heart desires.
SunSoaked is offline   Reply With Quote
Old 10-23-2019, 01:20 PM   #11
SunSoaked
SunSoaked's Avatar
And as for the parking brake, if needed, just remove it and slightly modify the lever. I put a slight dogleg in mine for clearance. Looks factory if you didn't know better.
Old 04-12-2020, 01:05 PM   #12
Chilly178
Chilly178's Avatar
Could you post a link for the low profile grills on amazon?
Chilly178 is offline   Reply With Quote
Old 04-27-2020, 01:23 PM   #13
bigmac73
bigmac73's Avatar
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
I upgraded mine with a better pioneer 6 inch but had to use these spacer because of the magnet size and depth
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
