Old 01-23-2019, 10:39 AM   #251
regan wilson
regan wilson's Avatar
Re: Project Screamer - '72 GMC K2500 + DD 4-53T
I don't think you are going to move the a-pillar.lol
Put the wood block on the edge of the door facing the pillar.
At least you can even up the gap. You might have to go back and spot weld
the frame to the top of the door.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 02-03-2019, 06:51 PM   #252
burnitg
Saved it!
I have been ignoring my air filter box interference problem for 18 months. In fact, I purchased an universal air filter to install because I was convinced that I couldn't make the one that I fabbed work. Here's the interference from post # 171:
Name:  Hinge-air filter interference side view.jpg
I finally got around to looking at installing the new filter the other day. Just for grins, I put the air box into the truck and discovered that by cutting off the stop on the hinge and scotching the box forward just a bit, I could make it fit. Here it is installed.
Name:  Right hood hinge after modification - 1.jpg
Name:  Right hood hinge after modification - 2.jpg
I welded a new stop on the hinge a bit further down so it should work just fine.
Woohoo!
burnitg is offline   Reply With Quote
Old 02-03-2019, 08:57 PM   #253
OutlawDrifter
In the words of John "Hannibal" Smith...."I love it when a plan comes together!".
Great work!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 02-05-2019, 10:38 AM   #254
lower50's
lower50's's Avatar
Looking great!! nice to see all the little problems are working out for you.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-07-2019, 02:22 AM   #255
rodbearing
rodbearing's Avatar
Thumbs up Re: Project Screamer - '72 GMC K2500 + DD 4-53T
Ah Ha! Sometimes you have to put things off like that to think about them for a while. I am that way. Now you can check that one off the list! Great job!
rodbearing is offline   Reply With Quote
Old 02-26-2019, 08:43 PM   #256
burnitg
I spoke too soon...
It happens all the time, I think that I'm done with a part of the truck and it turns out that I'm not. I posted a while ago that I was done with chassis mods. I wasn't.
I knew that I was going to have to move the front and rear bumpers up to compensate for my 2" body lift. I thought that I would just fabricate some new brackets and that would be it. After looking at the way that the front bumper is mounted to the chassis, I decided that modifying the chassis was the best solution.
Here's the truck with the body lifted and the bumper in its normal position.
Name:  Bumper before chassis mods.jpg
Here's the chassis before I started cutting.
Name:  Chassis before mods for front bumper.jpg
Here's the end of the chassis tacked into place.
Name:  Chassis mods tacked up.jpg
Here are the modifications complete.
Name:  Chassis mods complete for front bumper.jpg
Here's the truck after the modifications.
Name:  Bumper after chassis mods.jpg
I'll probably choose to modify the chassis again to move the receiver hitch up 2". I wont know until I mount the bed.
Old 05-17-2019, 08:13 PM   #257
burnitg
It's a thing of beauty..
I've been spending most of my time prepping the body & chassis for blasting and paint - boring stuff not worthy of a post.
But, I took the time to design a custom fuel tank. Like most folks, I'm not comfortable with 26 gallons of fuel, even Diesel, right behind the seat so an exterior design was a given. The truck had an auxiliary tank; but, I'm not happy with the "through the bed fill" and it has holes in it. I'm also not happy with putting the tank in the spare tire spot. I designed a tank that fits in the place of the old auxiliary tank and fills through the wheel well. I had Boyd Welding make me one from 1/8" aluminum. I received it yesterday.
Name:  Left Fuel Tank - side view.jpg
It's gorgeous! I'll be designing one for the right side soon.
Old 05-19-2019, 10:00 AM   #258
gmikkels
Awesome build!
Thanks for posting
Gene
gmikkels is offline   Reply With Quote
Old 08-11-2019, 04:04 PM   #259
burnitg
Back in black...
The chassis is back from powder coating. it looks great. I've thrown the axles back under it so it's a roller again.
Name:  Powder Coated Chassis.jpg
It's now officially done-done.
The cab, bed, etc. are at the media blaster's in Denver. They should be in the painter's hands by the end of the week. Then we will see what surprises the blasting has revealed...
Old 08-12-2019, 07:37 AM   #260
regan wilson
I wondered why there haven't been any updates. I'll be looking forward to the final assembly. The frame looks good. Hopefully the sheet metal comes back clean.
Old 08-13-2019, 03:03 PM   #261
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on the bumper mods on the frame. That looks great. That's awesome they are cranking out the paint work too! Maybe you can drive it around before your weather starts to turn.
Ryan
1969 Chevy milk truck
Old 08-14-2019, 06:24 PM   #262
mattfranklin
mattfranklin's Avatar
Originally Posted by burnitg View Post
It’s a runner!
I finally got the engine running...
When I read this I got flashbacks. Good ones. I love the sound. We had a 4-53 in lab at school. It was a rush every time we ran it.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 08-15-2019, 10:58 AM   #263
burnitg
I love the sound too. It’s the reason for this project.
It’s a small world. We lived in Lafayette for 25 years.
Old 08-16-2019, 07:44 PM   #264
burnitg
Surprise!
The body parts are blasted and at the paint shop. There are a few rust holes here and there and some questionable repairs.
Here's the left footwell as an example.
Name:  Left Footwell.jpg
There are no structural issues and the rust is pretty minor. He will make the repairs and proceed with painting.
I'm pleased. I expected the problems to be worse.
Old 08-20-2019, 10:23 AM   #265
lower50's
lower50's's Avatar
Thats good there are no real rust problems.
1951 MG TD
Old 08-20-2019, 10:50 AM   #266
burnitg
I was pleasantly surprised. Based on some of the other bodywork I found on the truck, I expected at least one spot to be totally rusted through and covered with Bondo.
Old 08-22-2019, 10:45 PM   #267
kipps
This reply is mostly so I can get email updates on this thread.
I'm really intrigued with this build. I've dreamed of similar.
My dream vehicle would be a round-eye squarebody with a single cab, long bed, dually(optional) with mud tires(or at least the look thereof). The engine would be a silver 453-t detroit. Air starter, sm465, advance adapters overdrive transmission, np205 with a twin stick conversion, driveshaft parking brake, air compressor mounted on one of the tranny pto's, hydraulic pump for the dump bed mounted on the other pto. In case you lost count, that's a forest of seven sticks bristling from the floor.
The starter would be actuated by a foot pedal mounted under the edge of the seat, and would be a pilot air valve which would switch the main air valve near the starter. No electric would be needed for starting. Some form of a generator/alternator would be used that would not require a battery. When the engine starts, the electric system comes on. When the engine dies, all electric power dies with it. The dash would be simplified with round surface mount gauges, and surface mount glass fuses directly on the dash. The speedometer would top out at 60.
It'd be interesting to try a rag-top conversion on the truck, and skip the side windows altogether. The cabin heater and defrost would be using an exhaust heat exchanger. The whole truck would be shot in military drab, and all pertinent service data is stenciled on the fenders, dash, and underhood in white.
Basically, what's the most macho truck I could build without looking like it has a lot of added on bits of trash? The overall theme would be a squarebody version of a military deuce-and-a-half truck. Problem is, the only practical value to this truck would be for hot-shotting, and even then, it would not be very pleasant driving for multiple days at a time. It would mostly be a piece of art, and an expensive one at that. Oh well, dreaming is cheap....
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 08-23-2019, 11:21 AM   #268
burnitg
Wow! That would be an awesome truck.
I considered an air starter for my build. I gave up on the idea because I don’t have the space under the hood for the air compressor nor the space under the bed for the air tanks.
Old 08-29-2019, 07:48 PM   #269
burnitg
Lookin' good...
We had some errands in Denver today so we stopped by the painter's to check on the old Jimmy. He's looking good.
Name:  Cab & Bed in Primer.jpg
Name:  Fenders & Tailgate in Primer.jpg
The body work is done and they are prepping for paint. He should be painted by the end of September.
Old 09-20-2019, 09:16 AM   #270
regan wilson
Those body panels are surprisingly clean. It should turn out really nice. Does this mean you will be driving by the Spring? I'm ready for videos.
Old 09-20-2019, 12:33 PM   #271
burnitg
Yes, I’m on track to be driving it by spring. One never knows...
I haven’t posted any videos. It will be a learning experience for me.
Old 09-25-2019, 02:48 PM   #272
burnitg
4-53T All Painted and Ready to Run...
I've painted and reassembled the engine.
Name:  4-53T Painted - right front.jpg
Name:  4-53T Painted - left front.jpg
Name:  4-53T Painted - right rear.jpg
Name:  4-53T Painted - rear.jpg
He's ready to run.
Old 09-25-2019, 03:34 PM   #273
Lemield
Lemield's Avatar
That is a thing of beauty!
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 09-25-2019, 07:00 PM   #274
OutlawDrifter
Very nice!
1991 Z/28, 6.0L/T56
Old 09-26-2019, 07:23 AM   #275
regan wilson
Looks awesome. Detroit Green
