02-07-2019, 11:18 PM | #251 |
Who Changed This?
Re: What did you do to your truck today.The 3rd chapter
Thanks!
02-08-2019, 01:47 PM | #252 |
Update on my new dual snorkel air cleaner. Drove it last night for the first time since putting it on and exactly what I was looking for. Only time you really hear any intake noise is when you are on it with the secondaries open. Otherwise pretty much as quiet as the stock one. And I know the engine is getting as much air as needed now.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
02-08-2019, 05:37 PM | #253 |
Killed my exhaust leak...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-08-2019, 06:23 PM | #254 |
Got busy and slung some filler on the speaker hole repair, put seam sealer on the door bottom repair, and rattle canned some DupliColor on everything. Paint doesn't match very well but hey she's a driver
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
02-09-2019, 01:44 AM | #255 |
Nice work RodnRudy.... One would never know there was a gaping hope in the door unless you show them.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
02-10-2019, 07:10 PM | #256 |
Dual snorkel made from the two bbl single snorkel.
Do it, Do it right, Do it right the first time |
02-10-2019, 09:17 PM | #257 |
Over the last few days installed the intake, finished the brake lines. Installed mounts to block, and the engine perches loosely. Installed bumper stops, finished painting heads, installed transmission mount, positioned the frame and lots of prep for tomorrow. We're dropping this and the transmission tomorrow, and not literally.
Bugs me the hoist won't center over the block while it's on the engine stand, legs are in the way. There might be enough room to help support the block using the transmission jack. Either way we'll make it work, so is the plan.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-10-2019, 09:25 PM | #258 |
Got my front passenger side frame rails cleaned up and coated today finally getting this side about ready to go back together.
Posted via Mobile Device |
02-10-2019, 10:04 PM | #259 |
started to mock up the exhaust system today if anyone has used this Kit( Flowmaster American Thunder ) and has some pictures they can share of the install Im going to have to modify the H-pipe to get it between & thru the trailing arm c-member and fab a bracket to hold the exhaust brackets to the shock member
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-12-2019, 12:52 AM | #260 |
Milestone today, we got the engine/trans. installed. It was as a full day. The mounts were a challenge, but one engine perch is nuts where it was, and the other off a 16th. I'll call it better than our earlier work (1993 rebuild). Went smooth with one caveat. We had the torque converter set, but when I got to the point to bolt it up I found the converter must have slipped forward, because it was already flush with the flex plate. It's my understanding that generally you have to pull it forward 1/8" plus to meet the plate. But the converter spun without much effort and bolts went smoothly, so I think we're good. EDIT: Really I don't feel great about that torque converter. Going to disconnect and double check.
These are my boys. The oldest worked with me all day. The truck is his birthright. He doesn't like Ochre. It will grow on him BTW, if anyone can recommend a water pump and starter for an original 402/400TH build it's appreciated. I'd like a cast iron pump. If it means no other mods and suits an original block to transmission, including the inspection cover then I'd like to upgrade the starter. I think some are smaller and lighter sounds right
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 02-13-2019 at 01:27 PM. |
02-12-2019, 10:34 AM | #261 |
x2
1970 C10 Short Stepper with 71/72 front clip. |
02-12-2019, 04:39 PM | #262 |
Put new distributor in and some wiring done.
Fuzzy |
02-13-2019, 03:06 PM | #263 |
Not done yet, but on the weekend I will be fitting my "Spot Light".
I got a NOS bracket of Ebay and a 6" light, nice old one with the correct length shaft, Ivory colored handle. It has the original GE lamp. I think it need a new wire, I pick it up this afternoon. I am not sure where I will wire it from, Maybe through a relay switched from the ignition. |
02-14-2019, 11:24 PM | #264 |
first drive since buying and wrenching on it!
took it to get gas... no issues! |
02-15-2019, 10:46 AM | #265 |
very impressive engine detail. I sorta have the same setup on my PCV, but was wondering if you used a tube nut to fasten it. Mine has a collar just RTV d keep ing it on
[url=https://flic.kr/p/2dnBcmX]20190215_094812
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-15-2019 at 10:51 AM. |
02-15-2019, 11:04 AM | #266 |
I used a regular -6 fitting with a nylon insert pushed in the fitting and then installed on pcv and carb. Smoke tested and no leaks. It was a pain and probably 2 hours work grinding on the fitting. Thanks
Fuzzy |
02-15-2019, 08:19 PM | #267 |
No Pics to show but I finished putting the doors back together with new glass run channels, window regulators, door relays, and whiskers. I'm amazed at the difference, windows are nice and tight now and roll up and down smoooth. And a shout to Randy500 for his spot on instructions on tear down and reassembly of the components.
02-16-2019, 01:00 PM | #268 |
X2 re Randy500.... Good looking repairs there Phil!
02-16-2019, 02:32 PM | #269 |
Got my motor torn down to a short block so I can get the heads rebuilt and replace the iron intake with an aluminum one.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-17-2019, 12:17 AM | #270 |
Got a lot done today. Repaired back panel. Finished the door which took way too many days to complete. I thought I was finished numerous times later to find it wasn't straight. Pulled the front and rear glass. Getting closer each day.
02-17-2019, 09:06 AM | #271 |
what motor ? what manifold ? what carb ? im looking to replace my stock manifold on SB stock motor had a 4 barrel holley on it when i purchased the motor thanks just looking for options .....
02-17-2019, 06:33 PM | #272 |
It's up on the two stage cribs I made, not too bad lifting it there in two stages.
02-17-2019, 07:06 PM | #273 |
Nicely done!
02-17-2019, 08:07 PM | #274 |
Nice work....now that you have er up in the air, what your next plans?....drop tranny, new exhaust?
02-17-2019, 08:37 PM | #275 |
I've put about 5000miles on it since bolt off resto so with it up in the air and the suspension is under load. I want to retorque all the bolts, clean, change some fluids, and give it a going over. I have to add some static electricity grounding straps. I'm finishing the wiring to the P/L, P/W and interior light door pins. With the truck being low and me old I'll take any easy way. Maybe some exhaust work.
