09-11-2019, 01:13 PM | #1 |
Steering Column Bracket and Wire
Hey gang,
I have two questions as I reassemble my column/dash. First are these brackets and the gap below the column correct? Seems off to me but I'm not sure how to correct it. Second - the bundle of wires coming out of the column - there's 8 in the ribbon but i also have a tan/gray wire with a connector on the end. i *think* this goes on the back of the cluster but can anyone confirm? |
09-12-2019, 12:19 PM | #2 |
Re: Steering Column Bracket and Wire
Nobody?
I did find this pic that seems to have the same gap, if not a little smaller. |
09-12-2019, 03:42 PM | #3 |
My truck is a bit of a turd, but same gap.
09-12-2019, 03:44 PM | #4 |
09-12-2019, 05:23 PM | #5 |
Gap here as well; bone stock rig. Had to post-I hate odd numbers!
-Bruce 1971 K5 Blazer 4WD |
09-13-2019, 02:28 PM | #6 |
To close the loop on my other question - the extra wire from the tilt column supplies power to the shift indicator. Non-tilts use the fiber optic cable.
On a normal wiring harness this would plug into the fuse panel. On my American Auto Wire harness I need to wire it into the cluster plug grey wire, doubled up with the stock grey dash lights wire. |
09-14-2019, 10:54 AM | #7 |
I took that bracket right off on mine because it looked like crap right from the factory.
09-15-2019, 07:07 AM | #8 |
Mine is off a 70 blazer. The fit is much better than yours is
Justin 1970 Blazer in progress |
09-15-2019, 12:42 PM | #9 |
Interesting. And you have the U bolt in place holding the column to the dash?
09-15-2019, 07:44 PM | #10 |
Everything there is stock and not touched to my knowledge
09-15-2019, 07:45 PM | #11 |
If you look at post #3 it looks like the bracket used to be up and covering everything. Somewhere along the way it got pulled down
