Old 12-05-2019, 12:27 PM   #1
dmjlambert
dmjlambert's Avatar
Fuel tank location options for long bed pickup
What are the fuel tank location options for long bed pickup such as my 1969 CST/10, assuming I would not want to get rid of the spare tire location under the rear of the bed? Are there any later model year or other model tanks that are available in reproductions that will just bolt up?
Old 12-13-2019, 09:47 PM   #2
May70
May70's Avatar
Re: Fuel tank location options for long bed pickup
You have a spare tire mount under the bed? Pics? Didnt know that was a factory thing.
I was going to put my tank between the last two cross members in the frame...
May70 is offline   Reply With Quote
Old 12-13-2019, 11:01 PM   #3
Rufas
Rufas's Avatar
When relocating my fuel tank on my 70 GMC long bed the only option I could find were tanks that occupied the spare tire area. I haven't seen anything else but haven't been looking.
1970 GMC 2500
700R Trans
RideTech 4 link rear suspension - Air Bagged on all four corners
350 SBC 300hp
Weiand Supercharger
FiTech EFI
Rufas is offline   Reply With Quote
Old 12-13-2019, 11:58 PM   #4
dmjlambert
dmjlambert's Avatar
It's probably stock on long beds and it seems very few of us like long beds, or standard beds as I prefer to call them.
I am not using mine now because I don't have a spare yet. It is on my list after I get air conditioning going. Here is one that is for sale with picture.
Name:  Screen Shot 2019-12-13 at 9.38.16 PM.jpg
https://offerup.com/item/detail/338284376/
I am interested in extra tank(s) in addition to the in-cab tank, and I'm going to gravity feed them from the in-cab tank, instead of having separate fill necks/caps. And I don't want to use the spare tire location at the rear of the truck.
Old 12-14-2019, 12:06 AM   #5
dmjlambert
dmjlambert's Avatar
I was hoping somebody would know if Blazer or Suburban had the under truck spare tire mount, and under truck tank or tanks tucked up under there as well, and perhaps reproduction tanks are available. But, I don't know about those trucks or the compatibility of their tanks with the C10 long bed pickup .
Old 12-14-2019, 12:17 AM   #6
Astro-Balls
Astro-Balls's Avatar
The aftermarket option in the day was to put in two saddle tanks, At the front under the bed.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 12-14-2019, 12:53 AM   #7
dmjlambert
dmjlambert's Avatar
Is it practical to do that today, or with time machine only? :-)
Old 12-14-2019, 12:57 AM   #8
Astro-Balls
I suppose the only drawback to it is the tanks are not within the frame rails, Not as protected?
Old 12-14-2019, 01:01 AM   #9
randy500
Factory NL2 driver side tank under bed, fills through side of bed. I have one for sale, unknown internal condition, i have one wiring harness and i think the valve, no switch though. I dont have the filler neck.
The factory tank is very similar to the aftermarket saddle tanks which most fill through a cutout in the side of the bed. Some rareish ones fill through the wheel well, much better option i think.
No blazer or burb had a spare mounted under the rear tank.
randy500 is offline   Reply With Quote
Old 12-14-2019, 02:08 AM   #10
dmjlambert
dmjlambert's Avatar
OK, "Factory NL2 driver side tank under bed"
I'm searching but don't find any pictures of where they mount on the truck or what they look like, especially when installed on a pickup truck. I would like to check where ever it is supposed to be mounted to make sure I have room to put it. I have an exhaust pipe I may need to relocate, depending on where the tank is supposed to go. I am not concerned about the fill neck, since I plan to use no fill neck at all, so I suppose I will weld that closed. I will use just one vent line at the top and one fuel line at the bottom, inserted in an all-in-one sending unit I hope. Are new sending units for these available?
Old 12-16-2019, 09:52 PM   #11
Rufas
Rufas's Avatar
I had those crappy saddle gas tanks along with those crappy piano hinge gas doors. That crap went in the trash along with the in cab gas tank. Now happy with an under bed rear gas tank and side bed gas fill.
[/url]
1970 GMC 2500
700R Trans
350 SBC 300hp
Weiand Supercharger
FiTech EFI
Old 12-16-2019, 10:10 PM   #12
kwmech
When I started building my flatbed I found a spot behind the cab--between the frame rails and above the exhaust and driveline. Holds (if my math is correct) about 45 gallons. Had it made from stainless steel. Still have the in-cab tank also. Think I'll run the aux tank as a main then switch to the cab as a back up, we'll see
kwmech is online now   Reply With Quote
Old 12-16-2019, 10:46 PM   #13
dmjlambert
dmjlambert's Avatar
Originally Posted by Rufas View Post
I had those crappy saddle gas tanks ...
What made you unhappy with the gas tanks?
Old 12-17-2019, 08:47 AM   #14
un4gvn!
un4gvn!'s Avatar
I agree with Rufas. I installed mine in the back also.
un4gvn! is offline   Reply With Quote
Old 12-17-2019, 09:59 AM   #15
whatwas
I know you said you didn't want it at the rear of your frame , so this post is a FYI for other forum members.
I am using the rear tank from my 1999 GMC 3500 dump . It fits like its supposed to be there, it has the fuel gauge sending unit, frame mount pump, its plastic ,and a heavy steel shell that even the bolt holes (2 of the 6) line up with existing holes in the frame. I had to make a cross member for the tank straps and I'm a little concerned about the tail pipe routing, but I was surprised and I wasn't using it in the 3500 anyway.
sorry for the hi-jack
whatwas is offline   Reply With Quote
Old 12-17-2019, 10:12 AM   #16
toolboxchev
I had those crappy saddle tanks, fill was located in the wheel well. Not good as the tire would throw mud and road crap all over it and the fill nozzle.
Have been wanting to do a blazer style tank in the spare location. Yet not wanting to cut the crap out of my rig. Thinking of throwing one in the bed. Yea scrap that more cutting.
I do know how many guys ruin the originality of their rigs cutting the sheetmetal to heck and gone. Always finding bed panels and part out rigs with this done.
toolboxchev is offline   Reply With Quote
Old 12-17-2019, 11:38 AM   #17
biketopia
[/url]
You guys have any more info on what tanks and filler necks you used? A lot of custom work, I'm fully aware of that, what fuel door did you use?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 12-17-2019, 02:29 PM   #18
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I don't know why anyone would want to put a door on the fleet side when you could have this setup for the gas fill only I'd put the fill on the drivers side. If this isn't good I think there are now kits being made to put the filler behind the drivers side taillight.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-17-2019, 09:01 PM   #19
dmjlambert
dmjlambert's Avatar
Does anybody have any pictures of saddle tanks installed and also what they look like apart from the truck? I don't know what they look like or exactly what space they occupy. This is for a fleet side long bed. I don't care about the filler neck location because I won't be using the filler neck.
Old 12-17-2019, 10:08 PM   #20
Chris_oz
Chris_oz's Avatar
Hello,
My 1970 C20 "longhorn" had 2 x dealer fitted auxiliary fuel tanks (they are on the invoice and order)
The are in front of the rear wheels, outboard of the chassis, the filler necks are in the wheel well.
They were hooked into the fuel system with a floor mounted manual 3 way tap/selector.
Mounts were long 1/2' dia bolts that ran down through the tank.
Fitted in 1970, still there not leaking in 2018.
They were just over 15.5 US gallons each.
Chris_oz is offline   Reply With Quote
Old 12-17-2019, 10:29 PM   #21
dmjlambert
dmjlambert's Avatar
That is interesting and informative, thanks. I wonder if that is a longhorn-only size, or if those would fit on a long bed pickup. I also wonder how the bolts go through the tank. I suppose maybe there is a tube that goes through the tank and is welded, do you think that's right? Do the mount bolts go through he floor of the bed?
Old 12-17-2019, 11:39 PM   #22
Chris_oz
Chris_oz's Avatar
The tanks I have would be too long for a regular "long-bed" as they run almost all the way to the cab.
The mounts are tubes, welded on each end, which the bolt passes through.
2 each per tank, bolts came down through the bed, large flat washers under the head of the bolts, about 1.5" in dia.
The bolts had similar large washers under the nuts, there were strips of rubber between the tank and bed.
They were held up very well and I am sure I could use them again if required.
Old 12-18-2019, 08:47 PM   #23
Rufas
Rufas's Avatar
The fill tank tubes are small and it's very tight getting your hand inside the panel to take the gas cap off. Filling is just a royal PITA.
Those piano hinge fuel door are just plain butt ugly, they rust and the paint peels off the hinges.
One more thing the tanks rust on the inside too.
1970 GMC 2500
700R Trans
350 SBC 300hp
Weiand Supercharger
FiTech EFI
Old 12-18-2019, 08:50 PM   #24
Rufas
Rufas's Avatar
Originally Posted by Chris_oz View Post
Hello,
Speaking from experience I guarantee those tanks are very rusty inside. Stay away from them. You'll get a lot of crap in your gas using them. I would use them. I had them and the best option is to either stay with your existing in cab tank or get a new rear under bed tank.
1970 GMC 2500
700R Trans
350 SBC 300hp
Weiand Supercharger
FiTech EFI
Old 12-18-2019, 10:18 PM   #25
Chris_oz
Chris_oz's Avatar
Hi,
The tanks are in my shed, I doubt I will ever use them, They do seem clean inside, but I have no need for them.
My truck had a 11ft Anza slide in camper fitted at purchase, I imagine the fuel use would have been high, hence the long range tanks.
Now it is just used for cruising, daily trips to work and collecting some firewood, the stock tank does me fine. I can get over 300 miles with ease before looking for fuel.
fuel tank
