Old 12-08-2019, 03:59 PM   #1
MrFinland
MrFinland's Avatar
BMW 325i 1989 restoration
I started a new project in this week. This is a original 325i and I'm going to restore whole car and I want more horsepower to this engine. Here are a few pictures on the restoration before and when I also started to detach parts of it.
MrFinland is offline   Reply With Quote
Old 12-08-2019, 04:13 PM   #2
MrFinland
MrFinland's Avatar
Re: BMW 325i 1989 restoration
Here are a few points what I need to fix at least.
Old 12-11-2019, 07:55 AM   #3
LT7A
Hi Ilkka! I usually don't read these projects but I was excited to see this listed for Mr. Finland. It already looks like a nice car but obviously has some areas that need to be fixed. This will be fun to watch. Happy holidays to you and your family!
LT7A is online now   Reply With Quote
Old 12-12-2019, 12:11 PM   #4
MrFinland
MrFinland's Avatar
Hi LT7A! Thank you very much for your kind words. This project will probably take longer than our Chevy took, because I will have to restore this car alone. But this car doesn't have as much repair as Chevy had. Have a nice holiday for you and your family too.
Old 12-12-2019, 12:33 PM   #5
MrFinland
MrFinland's Avatar
Here are a few more pictures of rust.
Old 12-14-2019, 02:40 PM   #6
MrFinland
MrFinland's Avatar
Today we lifted the engine out of the car. My brother was a big help and a big thank you to him.
The engine was not original because the block is year 1986.
Old 12-14-2019, 02:46 PM   #7
flashed
Not usually my kind of car but I like it . Are body parts available new or will you source them from a salvage yard ? What are your engine plans ?
flashed is offline   Reply With Quote
Old 12-14-2019, 05:42 PM   #8
MrFinland
MrFinland's Avatar
Thank you Flashed! New parts are still available and I already ordered the part below the windscreen. Front fenders I have to buy new or repair old ones. Many people say that aftermarket fenders don't fit well. Other rust repairs I'm probably doing straight sheet metal.
For this engine, which by the way is the M20B25 (2.5L 12-valve), I intend to install a 2.8L 24-valve (M52B28) crankshaft and pistons. The compression ratio is to be raised higher. The cylinder head is being modified. The camshaft becomes better. Exhaust manifolds will be better. Exhaust pipe bigger. Fuel injectors bigger. Adjustable motor control is very likely to occur. Lighter flywheel. Of course, all bearings etc. will be new.
I want the engine to look original but more powerful than new. I don't want to install a turbo even if it gets a lot of horsepower. For example, here's a YouTube link from a car in the same city as me. The owner of this car is a really skilled Tuner !!!
https://www.youtube.com/playlist?lis...2U-zbLcJZKJ1zh
I am happy if I can get to my car around 220-230 horsepower because the car is pretty light weight (1200 kg). New to this car have been 170 horsepower.
My English is pretty weak but hopefully you got it!
Old 12-14-2019, 07:56 PM   #9
flashed
Your English and explanation are perfect , waiting for more .
Old 12-21-2019, 07:15 PM   #10
MrFinland
MrFinland's Avatar
A few days ago I removed the cylinder head. There were deep scratches in the block. I have another block, but I'm not sure about its condition. I also have other pistons (lower) ready for the new crankshaft but they are standard size. So hopefully that second block is better.
Today I cleaned the gearbox and removed the valves from the cylinder head. I made my own tool for removing the valves.
Old 12-31-2019, 11:32 AM   #11
KShortell
KShortell's Avatar
Cool project. It looks like Heikki Lunta has been a little hard on it, but not too bad for thirty years worth. Thanks for posting!
Semper Paratus
KShortell is offline   Reply With Quote
Old 01-02-2020, 04:23 PM   #12
MrFinland
MrFinland's Avatar
Thanks a lot KShortell! Ha ha, Heikki Lunta has really been here, but hopefully I'll get the car repaired in the wake of his visit.
Old 01-02-2020, 05:30 PM   #13
MrFinland
MrFinland's Avatar
Now both engines are disassembled. And both engine blocks were bad, so I have to buy oversize pistons and drill the blocks bigger. I have tried to look for oversize pistons but quite difficult to find at least Europe. Ireland engineering Motorsport and Top end performance (both in California) and Metric Mechanic (also in USA) sell pistons but are very far from here. There is one company in Sweden where I can get the right pistons, maybe???
Here are a few pictures when the blocks are disassembled. One picture shows the "new" crankshaft (in the plastic bag) that comes into use. Only the "ring" shown in the illustration must be fitted to the front of the crankshaft first. The original crankshaft have a 75mm long stroke and this "new" has an 84mm long stroke.
Old 02-10-2020, 04:11 PM   #14
MrFinland
MrFinland's Avatar
The first time in my life I did the cylinder head porting. Hope I didn't spoil it!?! Exhaust ports I polished, but intake ports I did not polished. Last picture before porting.
Old 02-10-2020, 04:35 PM   #15
MrFinland
MrFinland's Avatar
I tried a little polishing the valves. These are the original valves and are reported to be of better quality than the aftermarket valves. New originals are really expensive and that's why I'm trying to get them refurbished.
Old 02-10-2020, 04:48 PM   #16
MrFinland
MrFinland's Avatar
Here is some photos of parts of what I have bought. For example, Schrick 272 camshaft, Schrick valve springs, 135mm Maxpeedinsrods connecting rods, stainless steel exhaust manifold, connecting rod bearings, gaskets, etc.
Old 03-18-2020, 09:32 AM   #17
MrFinland
MrFinland's Avatar
The engine is now being drilled by a professional, so I started repairing the rust spots on the car. The last picture shows what it looks like when it's new. So there's a lot of work to do because I want to fix it like the original.
Old 03-31-2020, 08:07 AM   #18
MrFinland
MrFinland's Avatar
New Wiseco pistons (84.5mm) have arrived. The pistons are 0.5mm oversized. The piston pins come from another manufacturer because the wiseco pins are too hard.
Old 03-31-2020, 08:14 AM   #19
MrFinland
MrFinland's Avatar
Here are some pictures of slow progress in rust repair.
Old 04-06-2020, 08:03 PM   #20
Russell Ashley
Russell Ashley's Avatar
I've been following along from the start. I had a BMW myself once and had to do some engine work on it too, but not as much as you are doing. Your rust repairs are looking good.
Russell Ashley is offline   Reply With Quote
Old 04-08-2020, 01:15 AM   #21
MrFinland
MrFinland's Avatar
Thank you so much Russell Ashley! Was your BMW also an E30 body model? Rust repair is really slow because I want it to look completely original and I haven’t bought ready-made repair pieces.
By the way. The engine specialist announced yesterday that the engine is now ready. I'm going today to get the engine home.
Old 04-13-2020, 06:40 AM   #22
MrFinland
MrFinland's Avatar
The engine is now pre-assembled. Only the block needs to be painted yet. The camshaft was different from what I had ordered from ebay. I ordered 272/272, but I had been sent a 284/272 degree camshaft. Hopefully I can get the emission measurement approved on that tighter camshaft.
Old 05-20-2020, 04:21 PM   #23
MrFinland
MrFinland's Avatar
The front right corner is now welded.
Old 05-20-2020, 04:48 PM   #24
MrFinland
MrFinland's Avatar
I started to fix the left front corner.
Old 05-29-2020, 06:51 PM   #25
Russell Ashley
Still following along. You are doing nice work. We don't have snow here so it was never driven in salt, so I never had to contend with any rust thankfully. My BMW was a 528E, I'm not sure if that was a E30 model as I never heard it referred to by that number. Keep up the good work.
